tuner help..
Old May 26, 2007 | 11:04 PM
GstangT's Avatar
GstangT
Default tuner help..
[posted in the 4.0 seciton, but I hope I would get more answers here]
Ok i have a problem, I installed my intake and went to install the tune but it said wrong vehicle! F***!! I bought the tuner from soemone here but now what do I do? He said he returned his to stock, and unmated it to his car. Now I don't want to return it to stock, it's a PITA and I don't have time.. so what's the easiest way? Is there no possible way but to buy a new tune?? I need some help quick! Thanks guys.. i really appreciate it.
Old May 26, 2007 | 11:12 PM
lldsandsll's Avatar
lldsandsll
Default RE: tuner help..
what tune do u have?
Old May 26, 2007 | 11:50 PM
tritonpwrd's Avatar
tritonpwrd
If its the xcal2 use the live load program from there site to unlock the programmer. Even though you return the previous vehicle to stock you must still unlock the programmer using live load in some cases.
Old May 26, 2007 | 11:54 PM
howarmat's Avatar
howarmat
s197 Junkie
+1
Old May 27, 2007 | 12:50 AM
GstangT's Avatar
GstangT
thanks! I'll try it first thing when I get home, yeah I have the xcal2, and it should be fine after that?
Old May 27, 2007 | 01:45 AM
GstangT's Avatar
GstangT
I unlocked it, it loaded.. now when i try to turn the car on, it seems like the battery just dies.. everything turns off when i turn the key to start it. it dosn't even click like it did before I had the tune loaded.. s***... now i'm lost.. can anyone help?
Old May 27, 2007 | 01:52 AM
hammeron's Avatar
hammeron
i was hoping you could dodge this bullet. you
may have locked up your PCM, by uploading
a tune with the wrong pcm calibration code.
this can be fixed so don't worry too much. i'll see
if i can find the links on this......
here are some read's on the subject:
https://mustangforums.com/m_3251691/tm.htm
ORIGINAL: GstangT
[/quote]
Old May 27, 2007 | 03:37 AM
GstangT's Avatar
GstangT
Damn.. I hope it's not that.. but I guess I'm gonna have to reinstall the stock intake back on there til I figure out what's gonna happen or if im gonna need to get a new tune. Anyone else with some other thoughts or had this happen to them please step in. Thanks
Old May 27, 2007 | 03:40 AM
hammeron's Avatar
hammeron
i think the worst case scenario, is that on
Tuesday you take your pcm to a ford
dealership, to have them reload the stock
tune for your VIN
everything will work out
Old May 27, 2007 | 01:55 PM
lldsandsll's Avatar
lldsandsll
ya just dont take it to the dealership where u would normally have warranty work done to it.
