Extra Play?
Old May 31, 2007 | 02:38 AM
Fletch's Avatar
Fletch
Default Extra Play?
I have a fairly steep driveway that levels out at the top. Usually I go up in 2nd (depends, sometimes 1st) and push in the clutch when the driveway levels out so that I can "coast" into my garage. However, I've noticed that sometimes when I push in the clutch just as I reach the top, I get a "clunk" noise. Almost like, the car is under a load, and when I release it, there is some slack somewhere in the driveline. I can't tell if it's coming from the rear end (3.55) or the tranny.
Is this normal? Any idea what it could be?
~Fletch~
Old May 31, 2007 | 03:29 AM
LegallyTorchRED's Avatar
LegallyTorchRED
Default RE: Extra Play?
You may need to learn how to "feather" that clutch.
I've found that the clutch wants to"work", at low RPM, and actually wants to keep going.
This is a hydraulic clutch, that is "driver" friendly, unlike the "spring loaded clutches" of yesteryear.
The "clunks", and "jerks" you are having, are from driver error, and inexperience,..... don't worry,...... or feel bad, you will learn how to drive it.
It's really not the car's fault, it's yours. But, you'll be OK !!
Old May 31, 2007 | 12:02 PM
Fletch's Avatar
Fletch
Thanks for the advice. I was taught how to drive stick by an 'old timer' who warned me not to play with the clutch. That it should either be in or out, with smooth transistions. So, when I feel the clutch start to grab, I usually don't hold it there because, naturally, I feel like I'd be burning it up.
~Fletch~
Old May 31, 2007 | 02:35 PM
06VistaBlueGT's Avatar
06VistaBlueGT
More than likely that noise you are hearing is the 2 piece driveshaft. That thing makes more noise than....well lets just say it's noisy.
Old May 31, 2007 | 03:30 PM
Fletch's Avatar
Fletch
I've heard that. That was my initial feeling too.
~Fletch~
fastbackford351
Oct 1, 2015 12:24 PM
gagemcc
Sep 22, 2015 09:43 AM
movielover40
Sep 15, 2015 10:37 AM
Doogie65
Sep 6, 2015 02:55 PM
