Floor Jacks
Old Jun 1, 2007 | 01:03 AM
Mikes_BLK_GT's Avatar
Mikes_BLK_GT
Default Floor Jacks
What are you do it yourselfers with lowered s197's using for floor jacks these days?
Craftsman has one thats low profile but it's a4 ton jack and I'm not sure I need that much jack but wonder if I need the low profile since my car is lowered about 1.5"
Old Jun 1, 2007 | 01:04 AM
drbobvs's Avatar
drbobvs
Default RE: Floor Jacks
Do an online search for "race jack" and you'll get plenty of choices.
Old Jun 1, 2007 | 01:38 AM
Thunderbutt's Avatar
Thunderbutt
Try your local Costco. Low profile, aluminum, fast double pump, chromed & polished, looks like it costs $400.00 but is only $99.00
Old Jun 1, 2007 | 03:44 AM
Orion_240's Avatar
Orion_240
and how about some photos of the jack points?
I'm getting the brake caliper paint soon and will need to jack my GT up. Have heard horror stories about jacking in the wrong place.
Old Jun 1, 2007 | 06:39 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I jack up the car in the front on the A- arms and the back on the rear diff (careful not to bend diff cover) or the rear axle itself on either side of the diff. I know I will get crap for saying on the rear diff but it is flat and wide and very easy to stay from the diff cover. You can put jack stands anywhere on the rear axle or anywhere along the frame rails that run the length of the car on each side. Works for me and no problems at all! JMO J
Old Jun 1, 2007 | 07:39 AM
howarmat's Avatar
howarmat
s197 Junkie
http://www.harborfreight.com/cpi/cta...emnumber=91039
I got one justlike this from autozone.....works great.
Old Jun 2, 2007 | 04:11 PM
157dB's Avatar
157dB
Cut & Paste Expert
I drive up on 2 2x6s nailed together and cut on an angle to
get it up high enough to get the floor jack I now have under it.
I removed the contact plate from the jack and made an aluminum
plate that has a pin on it that fits into a hole on the front frame.
This has rubber on it to prevent scratching. In the rear I replace
the stock jack plate and use the axle tubes. The diff housing
is not strong enough and it will bend somewhat causing leaks
Old Jun 3, 2007 | 12:12 AM
RICVA05's Avatar
RICVA05
I currently have a low profile race jack and it is still a pain to use.But this jack is going to be my next purchase http://www.atdtools.com/showitem.php?item_id=7325 although it is heavy as sh**.
Old Jun 3, 2007 | 01:26 AM
Lees07GT's Avatar
Lees07GT
ORIGINAL: mygt500
The 07 Mustang Factory Service Manual states the following:
" ! CAUTION: Never use the differential housing as a lift point. Damage to the differential housing and cover may occur."
Old Jun 3, 2007 | 01:35 AM
howarmat's Avatar
howarmat
s197 Junkie
Yeah we have all read that and we all ignore it.....its a CYA for ford
