Hose Clamps????
Old Jun 10, 2007 | 06:42 PM
1BADD05's Avatar
1BADD05
Default Hose Clamps????
What is the deal with the hose clamps on our cars from Fords? Starting to change a few things and these clamps are a B**ch to get off, Any quick tricks?
Thanks
Old Jun 10, 2007 | 07:14 PM
offrdmania's Avatar
offrdmania
Default RE: Hose Clamps????
Pictures sure would help but most Ford clamps have slots in them to keep them from rotating when tightening. If it is your intake you will see a piece of molded rubber sticking through the slot. You have to loosen them considerably more than a standard clamp to get them free of the rubber in the slot.
Old Jun 10, 2007 | 07:57 PM
hammeron's Avatar
hammeron
if you're talking about those pinch clamps, yes
they're a pita. there is a special tool you can
get at sears or most autoparts stores.
i have found that a pair of large channel lock pliers
really work well, for most of these pinch clamps and
i even have the special clamp tool
ORIGINAL: 1BADD05
Thanks
Old Jun 10, 2007 | 09:05 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
The pinch clamps are mainly on because its easy for a machine to install them on the assembly line. I have a cable tool at work that makes taking them off a million times easier. I usually replace the ones I can with the regular screw type style.
Old Jun 10, 2007 | 09:37 PM
1BADD05's Avatar
1BADD05
Yea that is what I plan on replacing them with. I am working on the Power steering tank at the moment.
Old Jun 11, 2007 | 12:36 AM
Tracedaddy's Avatar
Tracedaddy
Be thankful yours are functioning. My lower hose clamp was never "activated" and hung loose. (It was locked open for assembly ease and was never actually clamped onto my hose.) I didn't discover that until I dumped all my antifreeze on Hwy 26 and overheated.
Old Jun 11, 2007 | 04:04 PM
Leoleo's Avatar
Leoleo
Same with my clamp. Except mined dumped after I drove the car and parked. Guy came to me in the bar and said, "your blue Mustang just dumped all it's antifreeze all over the parking lot"
lmurf60
Sep 24, 2015 10:07 PM
Demodulates
Sep 18, 2015 11:14 AM
TfcCDR
Sep 14, 2015 12:08 PM
MusicCity615
Sep 12, 2015 07:05 AM
