Grease Zerks
Old Jun 15, 2007 | 10:31 AM
ndfan's Avatar
ndfan
Default Grease Zerks
I am doing my latest oil change on my '06 GT at 15,000 miles and the manual states that I should grease the zerks (if so equipped). Of course, the manual really doesn't definitively say if there are, or there aren't, any zerks. I recall checking my front suspension and steering and seeing no zerks while doing a previous oil change. So, here's my question... Does anyone know for sure if there are zerks for the front suspension and/or steering, as well as other places, such as the two-piece driveshaft? Thanks!
Old Jun 15, 2007 | 11:21 AM
moosestang's Avatar
moosestang
Default RE: Grease Zerks
None that I know of. All the suspension uses rubber bushings so no grease. There is no maintenance to do on the driveshaft.
Old Jun 15, 2007 | 04:03 PM
ndfan's Avatar
ndfan
Thanks Moosestang for the info! Can anybody confirm for sure if there are any on the front suspension/steering mechanisms?
Old Jun 15, 2007 | 06:07 PM
157dB's Avatar
157dB
Cut & Paste Expert
Conformation on there being NONE.
The shop manual for the 07 shows
NO zerks nor mentions geasing anything
that has a zerk fitting. ZERO, NONE.
Thanks again, FORD.
I also like my underdash water dispenser.
Old Jun 15, 2007 | 06:17 PM
wthalliii's Avatar
wthalliii
ORIGINAL: 157db
Thanks again, FORD.
Not to mention, thanks for the automatic transmission with no dipstick.
Old Jun 16, 2007 | 03:07 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Seems Ford likes to cut corners on some things. Most aftermarket suspension components will have them so I guess I can use mine when they are installed!
Old Jun 16, 2007 | 05:36 PM
Archion's Avatar
Archion
You will find that most if not all late model vehicles, except HD apps, have no grease fittings. The oe suspension components are factory sealed with very tight tolerances and with not only grease inside, but teflon bushings and spring steel as well. This is not a form of being cheap, but being better designed. My 99 still has all the suspension components stock and still as tight as the day they were new after 145k very hard miles, Ido tend to beat on my cars a bit,incudingseveral in NewHampshire with their re-paved cowpaths. The after market components (stock style) are actually made cheaper than oe and usually in china these days.
The no dipstick thing does annoy the **** out of me though...
6bangr
Feb 15, 2016 07:40 AM
guitarman376
Oct 11, 2015 01:47 AM
allenmaty
Sep 24, 2015 09:17 AM
unit91
Aug 31, 2015 10:27 AM
JonnyBlazeGT
Aug 9, 2015 10:19 AM
