brake question...
Old Jun 20, 2007 | 02:26 AM
sdsguy's Avatar
sdsguy
Default brake question...
so i've been toying with the idea of getting new brakes...changing pretty much everything...the rotors, pads, and anything else that would need to be changed and i wanted bigger rotors. i like the look of bigger rotots especially since theres a lot of room. my brakes kinda look like a bottle cap in pam anderson after tommy lee had a go.. i want them to fill out that gap a little more.
i was thinking of slotted rotors but what's the biggest rotor i can get to fit in my 17"s? i'm thinking of getting some paint for the calipers, any specific kind or paint needed?
btw, it's an '05 v6 if that changes things.
Old Jun 20, 2007 | 02:53 AM
dodgers's Avatar
dodgers
Default RE: brake question...
Bigger rotors means bigger calipers!!!!!!!!!!!
Old Jun 20, 2007 | 03:11 AM
Orion_240's Avatar
Orion_240
If you want the big calipers don't you need bigger rims than just 17s?
At least 18's
Old Jun 20, 2007 | 03:25 AM
rmays06's Avatar
rmays06
ORIGINAL: dodgers
HUH' um no not really!!!
SDSGUY- there is a few options- 1st here is a great read: https://mustangforums.com/m_2547493/...tm.htm#2547493
2nd the easiest is to go with a GT take off kit which is about $100 to $200 depending on where you go. It has bigger rotors but we (GT V6) have the same calipers. The bigger rotors has biggest impact other than that its basically the same system. You can use this with the stock 17" bullit. Other kits I'm not sure
The easiest way to improve braking is to get better pads, change the fluid and put on stainless break lines. Combined with bigger rotor its fool proof.
Othere options are to get a complete kit, SSBC, Baer, ETC....
If you get bigger rotors the most crucial part is the break clips/clams are the most expensive part probably. They cost around $40 each.
Good luck and make sure you read the thread above. (crazy al is the man)
Old Jun 21, 2007 | 08:18 AM
rmays06's Avatar
rmays06
DID this help?
Old Jun 24, 2007 | 04:02 AM
sdsguy's Avatar
sdsguy
ORIGINAL: rmays06
DID this help?
yea sorry, i lost my post. i wasn't planning on doing slotted or drilled rotors. i've heard aboutt he cracking and so forth. besides, that's super expensive.
i was actually looking at my brakes today, my calipers are pretty close to the rims...i dont know if i can fit a bigger rotor.
here's a pic
http://i81.photobucket.com/albums/j2...a/PC270189.jpg
Old Jun 24, 2007 | 04:08 AM
rmays06's Avatar
rmays06
Alot of GT's have 17's as well. Before you order anything talk to a guy.
Check out rotorpro's to. Good guy and is in LA area. Pretty inexpensive.
Old Jun 24, 2007 | 04:26 AM
sdsguy's Avatar
sdsguy
cool, thanks for your help!
Old Jun 24, 2007 | 04:36 AM
rmays06's Avatar
rmays06
No problem did you get your ride from Mossey ford?
Old Jun 24, 2007 | 09:56 AM
ZZmustang's Avatar
ZZmustang
Banned
Check the distance between your caliper and your wheel, That’s how much bigger your rotor can be, Wheel diameter is not the only thing to look for when thinking rotor diameter. I put some 17 Fooze and 17 Boyds on the front of my car that had 17 Ford on , and neither Fooze or Boyds would clear the caliper. I got 18 Fooze.
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
