Anyone tried a throttle body spacer?
#31
RE: Anyone tried a throttle body spacer?
Sounds like someone is going to have to decide this one with a couple of dyno runs.
For my part my mechanic said if I put one on he's takin it off. Upitty mechanic! LOL.
#32
ORIGINAL: odiaz
If you want to get into the science of it, the throttle body spacer is based on the bernouli principle. The diameter of the TBS is slightly smaller then the throat of the trottle body. As a consequence, the air volume is subjected to greater pressure reulting in the speed of the air increasing as it flows through the throttle body.
When a spacer is placed beneath a carburetor atop an intake manifold, these effects of increased flow rates and changes in pressure do, indeed, have the potential to improvefuel atomizationefficiency and can, therefore,have a positive effect on horsepower and fuel economy. However, in our cars, fuel is sprayed via injectors into the airwell downstream of the where the spacer is located. The only way I can see the spacer having any beneficial effect is if it creates some sort of air turbulence so great that it is felt downstream at the injectors, somehow affecting fuel atomization at thepoint of injection. In any event, the throttle body spacer in our cars would have to work on a completely different principle than the classic carburetor/intake spacers or the throttle body injector/intake spacers due to theradically different architecture and method used forinjecting and atomizing the fuel. IMO, I doubt that a TBspacer doesanything of substance in our cars, but if someone who is totally impartial to this discussion would like to do a thorough dyno test, Iwould be very interested to read the results, one way or the other. Maybe MM&FF should do a test, or would the results possibly offend vendors/advertisers such asSteeda?
