HURST STS INSTALL HELP!!
Old Jun 21, 2007 | 08:47 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Default HURST STS INSTALL HELP!!
Hey guys, Ill be installing a Hurst STS in mine and my friends cars this weekend. Any help, hints, pitfalls to lookout for, whatever help there is to make an easier install will be greatly appreciated. My search function keeps screwing up asusual and besides I would like some fresh info. I saw a link once to a step by step install. That would be nice to find again. If you dont want to help or want to write some crap about its been written before or search for it, I really don want to hear it. If you got the time to type bullsh!t, then give me something I can use. The title says it all so if you dont want to hear it, you shouldn't have come in. To all the other, class acts, thanks in advance for your help.
Old Jun 21, 2007 | 09:00 PM
Aziraphale's Avatar
Aziraphale
Default RE: HURST STS INSTALL HELP!!
MGW but I gotta imagine a lot of steps are similar.
https://mustangforums.com/m_3000094/tm.htm
Old Jun 21, 2007 | 09:06 PM
howarmat's Avatar
howarmat
s197 Junkie
use the search idiot![sm=chairshot.gif]
http://www.stangnet.com/Tech-Article...ll-061016.html
http://www.fordmuscle.com/archives/2...fter/index.php
http://www.cardomain.com/ride/2177534/6
I had another write up but couldnt find it. It is pretty easy, the only problem i had was the stock shifter moving when trying to remove the 13mm bolt. Good luck!
Old Jun 21, 2007 | 09:17 PM
jdback19's Avatar
jdback19
Easy as your sister.
Old Jun 21, 2007 | 09:45 PM
moosestang's Avatar
moosestang
You'll think it's impossible to remove the stock shifter from inside the car, but it's not. Take the body mount bushing off the back of the shifter and tilt the front down as far as possible and pull the *** out first.
Old Jun 21, 2007 | 10:07 PM
sleeper2's Avatar
sleeper2
3 things (that are probably mentioned elsewhere)
1. If you remove the whole floor console and not just the trim you will have a bit more room and won't worry about scratching anything. (just unclick the power point(s) first).
2. To put the Hurst shifter in from the top, drop the whole thing front first till the whole shifter is wayin there (don't let go!) When half your forearm is in there, then you can position it as you pull your arm back out again.
3. That gear wrench (ratcheting box wrench) is your best friend.
Have fun.
Old Jun 21, 2007 | 10:42 PM
Dumpweed's Avatar
Dumpweed
ORIGINAL: jdback19
do happen to have his sisters number? the girl broke up with my *** a month ago, ummm, its been a long month
Old Jun 21, 2007 | 11:19 PM
Saleen#468's Avatar
Saleen#468
its a peice of cake with two people. just read the instructions and youll be fine. I didnt remove the console on mine. it will fit through the hole but its a tight fit.
Old Jun 21, 2007 | 11:55 PM
probinator's Avatar
probinator
use lock tight man.... and check the bolts every 3 months. or when you have a chance to look at them.
Old Jun 22, 2007 | 12:06 AM
GT4HUTCH's Avatar
GT4HUTCH
yeah you right. Use locktite. you'll need a 10mm deep socket also if you don't already have one. With two people it's a simple job. Removing the stock shifter is a sinch, but pay attention to how you have to cant it to get it out of the console. Install the husrt the same way the stocker came out. Nothing but 4 bolts, then screwing the **** on. Use use use use locktite. the bolt on the front of my rail arm came loose and you could see the shifter move with the torque of the engine. put some locktite and bolted it back up and there have been no problems.
HUTCH
