O2 sensors with LT's
Old Jun 25, 2007 | 11:56 PM
JGT's Avatar
JGT
Default RE: O2 sensors with LT's
If you use MIL eliminators, won't you be able to pass the test, as long as there is no visual inspection?
Old Jun 26, 2007 | 12:50 AM
MusiccityGT's Avatar
MusiccityGT
If you have cats, and both thefront and rear sensors are active in your tune, you will still pass with L/T's. The processor will complete its self test which will be recorded and they will see it when they hook to the OBDII port to check it. I have checked mine with a Ford diagnostic computer to confirm this. Eliminators will fool the computer into thinking that the rears are hooked up and will not trigger a check engine light, but I do not think they will allow the processor to complete its self test which would still fail you.
In laymans terms, when they hook up to the cars computer, they immediately see if the on board self diagnosis is complete and good. If it is incomplete, you fail. That way if you have a check engine light for any reason, emissions or otherwise, and try to clear it and run right back through the emissions station before it triggers again, they know it and still fail you. It takes quite a few miles before the computer completes its self diagnosis and records as good.
Old Jun 26, 2007 | 12:55 AM
MusiccityGT
ORIGINAL: BigDave
Thanks Musiccity!
If my values do not set when I go in to re-inspect, I guess my sensors got toasted when I was running too rich. In NC, if you flunk inspection twice and spend $200 trying to repair the emissions, you get a waiver.
My Pleasure. It should work unless you have a bad sensor, but thatwould trigger a check engine light. With the K/B tune you are running, are you certain they did not turn off one or more banks of o2 sensors? If so, you will never show a completed self test in the Spanish Oak. The canned K/B tune should have them all active, but if you have a custom tune, they may not be.
Old Jun 26, 2007 | 01:47 AM
JGT's Avatar
JGT
That is the first I have heard of the MIL eliminators causing a failed emissions test. Sounds like some vendors will tell you anything just to sell some longtubes.
So, your only chance of passing an emissions test with longtubes is to have the rear 02 sensors active and you just have tohope that you don't have any codes for awhile?
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
TfcCDR
Sep 14, 2015 12:08 PM
