Painted mirrors (Finally!!)
Old Jul 9, 2007 | 10:59 PM
  #21
lldsandsll's Avatar
lldsandsll
Default RE: Painted mirrors (Finally!!)
they came out very smooth, i screwed up a small area when wet sanding, but other then that barely noticeable blemishthey match the car perfectly. $5 for paper, $5 for primer, paid $60 to have em painted.
Old Jul 9, 2007 | 11:28 PM
  #22
fairlane292's Avatar
fairlane292
ORIGINAL: GT Guy
ORIGINAL: s2k
When you sand your mirrors wear gloves! I diden't it sanded myself on accident and when you sand fast it creates friction and it got hot REAL FAST. I wonder if using 100, 200, 300, primer, 400 wet sand, 400 dry would bring the same results?
hows about i mail you my mirrors and you tell me
so about how many hours would you say went strictly to sanding? i would love to do it myself but i would rather do it all at once even if it took the entire day, that way i won't have to drive around with half *** mirrors until i'm done
Hour and a half sanding each one. 60 80 100 (all dry); 220320400 (all wet) [3 hours total sanding]
No need to sand after adhesion promoter or primer if doing in straight sequence through base and CC. otherwise just sand after adhesion-promoter/primer is done, with 400 wet (the day before you bring to the shop)
Old Jul 9, 2007 | 11:51 PM
  #23
ohnoesaz's Avatar
ohnoesaz
Let me throw these questions out there... (Ive read cherod's write-up but still confused...)
1. Is the adhesion promoter used as the primer? Or is primer needed after the promotor?
2. Once sanding is finished, go to the promoter then paints, with no more sanding being done?
3. If Im correct let promoter dry for 6 hours then base coat it, let dry for 5 minutes then basecoat again, let dry for 25 minutes then clearcoat, let dry for 5 minutes then another clear coat?
Old Jul 9, 2007 | 11:58 PM
  #24
MustangBatman1's Avatar
MustangBatman1
thanks for the info, if i can get the paint by next weekend ill have a project on my hands
Old Jul 10, 2007 | 08:38 AM
  #25
fairlane292
ORIGINAL: ohnoesaz
For primers, base and clear I use autobody supply paints and my own guns; so I'm not using spray cans but if you are, simply follow directions on them. Generally you do not sand between paints, you spray one after the other has dried 20-30 mins(if you get a run then you have to sand it out). I did use Bulldog adhesion promoter in aerosol.
1) the adhesion promoter is not used as the primer; primer goes over it.
2) Once sanding is finished, go to the promoter then paints, with no more sanding being done. The only sanding would be to correct a run or if you are a professional with clear coat you will sand it with 2500 or 3000 and rotary buff to a no orange peel finish.
3) Sounds like you are using all aerosol cans, simply follow instructions there and in the absence of any on this let dry 30 mins before next step.
Old Jul 10, 2007 | 02:43 PM
  #26
s2k's Avatar
s2k
Well sorry for the delay but here's the pics!
The stangs kinda dirty, oh well.
For Comparision's sake
Old Jul 10, 2007 | 03:26 PM
  #27
fairlane292
Car is sooooooooooooooo nice!! love the clean look and I'll tell ya I've seen so much of the custom rim that the silver bullit rim looks mean! ...nice job man! ya gotta be proud!
Old Jul 10, 2007 | 04:18 PM
  #28
MUSTANGEXPERT's Avatar
MUSTANGEXPERT
looks good nice job
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
