Engine swap
Old Jul 13, 2007 | 03:15 AM
gula187's Avatar
gula187
Default Engine swap
well guys after hours of thinking im stuck once again..ok im going to go with a V6 for insurance reasons.but instead of getting a powerpak and /or a supercharger an probally more mods i've decided to just go with a complete engine swap...is this a good idea or not? i was lookin at this
http://i150.photobucket.com/albums/s...007-A351ft.jpg
Displacement 392
HP 430
Torque 450 ft./lbs.
Key More Cubes and Horsepower
Comp. Ratio 9.7:1
Heads X303 GT-40
Camshaft Z303 Hyd. Cam Crane Hyd. Cam
Crank 3.85" Stroke Cast Crank
Pistons 4.030" Forged
Intake Victor Jr.
Distributor MSD Billet Distributor MSD Billet Distributor
Valve Chrome Ford Racing Chrome
Oil Pan Front T-Pan 7qt. Rear T-Pan
Waterpump Serpentine Belt and V-Belt
MSRP $7,800.00
Old Jul 13, 2007 | 03:48 AM
Diabolical!'s Avatar
Diabolical!
Default RE: Engine swap
By the time you got that engine working properly in an S197, you'd have easily spent double that price.
Old Jul 13, 2007 | 03:52 AM
Apoptosis's Avatar
Apoptosis
poptart tits
Have fun mounting that bish.
20k in mods ftw!
Old Jul 13, 2007 | 05:18 AM
01harleydude's Avatar
01harleydude
if you feel like wasting your money go ahead. i see you havent factored in labor cost for the swap. just buy the gt and be done with it. much cheaper in the long run.
so your going to buy a v6 for insurance reasons and then drop a v8 in it and not tell your insurance company? i bet that will go over well when you get in a wreck.
Old Jul 13, 2007 | 07:37 AM
JimC's Avatar
Super Moderator
By the time you get done with the swap, won't the total price exceed the difference in insurance premiums? How much more is your insurer going to charge you for the V8?
Old Jul 13, 2007 | 07:55 AM
mightymouse's Avatar
mightymouse
one other thing, it most likly wont pass state inspection.
Old Jul 13, 2007 | 08:46 AM
jerjan's Avatar
jerjan
Too much work, Then you have a car that would be very hard to sell afterward. Won't pass any smog tests, probably would rip the V6 rear end gears to shreds too.
Old Jul 13, 2007 | 09:25 AM
jrm1900's Avatar
jrm1900
I agree with the other guys, it is not a good idea unless you are rich and use your mustang for racing only. Expense-wise, besides the insurance, emissions etc, an engine like that, either carburated or fuel injected willdrink fuel as if it was free.
Old Jul 13, 2007 | 09:27 AM
unsocbl's Avatar
unsocbl
+1000
Just get the GT
Old Jul 13, 2007 | 09:40 AM
bascho's Avatar
bascho
Emissions is only an issue in a emissions testing state. Mounting that engine is the easy part.....very easy. If you go with a carb then getting it to run correctly will be very easy. The bigger issues will be the trans and rearend.......neither are strong enough for that engine swap. Replace the trans with a Tremec and find a rearend from a GT.....both items are not going to break the bank. You will most likely need a custom driveshaft as well. As someone said above, you'll spend another $7-8K on topof the engine purchase, IF you are not doing the labor yourself. If youare doing the wrenching and welding.....then this swap is not going to run more than 12K tops. $8K for the engine, $2K for the trans, $1K for the rearend, $1K for thecustom driveshaft. Electrical won't cost you anything and your existing fuel system should be enough......BAPis not terribly expensive.
I thinkonce the warranties run out on the S197's we're going to see a lot more of theseswaps taking place with the sixers. You can build a 351W much cheaper than $8K....so if $12K sounds too high you can cut a fewthou off that estimate by finding a 351W in a scrap yard and having it machined. Build the engine yourself if you can......it's not that difficult.
