Crankshaft
Old Jul 13, 2007 | 06:18 PM
NVRL8's Avatar
NVRL8
Default Crankshaft
How durable is the stock crank? This post explains what happened https://mustangforums.com/m_3507349/...tm.htm#3507349
The bolt can't be removed without damaging the threads in the crankand there is also an ez out broke off in the bolt soa new crank has to be installed.So while the motor is out i'm having manley forged rods and pistons installed and having the block machined,blueprinted and balanced and keeping the procharger but raising the boost to around 14-15 psi. But if the stock crank can handle the power should there be a reason to go witha differentcrank.
Old Jul 13, 2007 | 06:54 PM
s197richie's Avatar
s197richie
I ♥ Acer
Default RE: Crankshaft
^^^ steeda says 420hp on factory cast rotating assy, some on this forum say a little more than that, and some say [sm=bs.gif]"I have a million rhwp and have been running the factory internals for 3 years 500 track runs etc etc etc"
....so I say, 420hp...
Old Jul 13, 2007 | 07:12 PM
ohnoesaz's Avatar
ohnoesaz
Hmmm, interesting. Only 420? Less than I thought... That means even the most mild of superchargers wil be maxing the engine out. Darn.
Old Jul 13, 2007 | 07:59 PM
ohsixgt1217's Avatar
ohsixgt1217
Yeh i wouldnt go anything over 8 lbs of boost with stock internals. If you are replacing everything else you should replace the entire bottom end to make it worth it (which will just be the crank in your case). Once you do that 14-15 lbs shouldnt be a problem.
Old Jul 13, 2007 | 08:28 PM
bentpushrod's Avatar
bentpushrod
A machine shop should be able to remove the bolt. I broke a crank bolt on a 351C that I built 20 years ago. I also broke an ez out off trying to remove the bolt. I pulled the crank and brought it to a machine shop and they drilled it out. retapped to the next bigger bolt and I was all set.
bryan616fl
Jan 25, 2019 09:07 PM
S'PortMustang69
Aug 30, 2015 08:27 PM
Nichepi
Nov 17, 2005 02:36 AM
uedlose
Aug 21, 2005 05:58 PM
blue50lx
Aug 4, 2005 11:55 PM
