JLT2 intake
Old Jul 21, 2007 | 11:59 AM
NyFordTech's Avatar
NyFordTech
Default JLT2 intake
I was outside cleaning the engine bay on my 07 n relized my intake is slightly resting on the upper radiator hose. anyone else have this problem.
Also im not 100% satisfied with the intake the shield for the filter dosnt really look as good as c&l. F uck it, it'll be fine till i get my procharger, but as for rubbing on the radiator hose any one notice that i may shim the heat sheild with washers so the intake gets held up higher.
Old Jul 21, 2007 | 12:13 PM
Black GT's Avatar
Black GT
Default RE: JLT2 intake
ORIGINAL: NyFordTech
I just looked at mine, there is at least 3/4" space between the intake and the upper radiator hose.
Old Jul 21, 2007 | 02:22 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
I trimed the hose about a 1/4 of an inch on the bottom by the thermastat housing to bring the hose lower and clear the piping. The shield I had to trim where it was rubbing near the brake lines.
Old Jul 21, 2007 | 04:50 PM
06tyrfryr's Avatar
06tyrfryr
it is close on mine, I wrapped my radiator hose with high temp wrapping so It is easier to cool the intake down between elimination rounds. the JLT II is a good intake. I gained 22 hp with it on my car
Old Jul 21, 2007 | 05:47 PM
Stoenr's Avatar
Stoenr
My JLTII came with a little piece of plastic tubing to put over the hose to prevent it from direct contact from the hose.
Old Jul 21, 2007 | 07:26 PM
moosestang's Avatar
moosestang
+1
Moving it up higher will just cause more rubbing on the hood, which is better than the radiator hose of course.
ORIGINAL: Stoenr
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
bradleyb
Nov 27, 2015 07:50 PM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
