Something rubbing/rattling into the underbody.
Old Jul 29, 2007 | 12:20 PM
Menace's Avatar
Menace
Default Something rubbing/rattling into the underbody.
Well, I switched out my SLP Loudmouths and put the Stock mufflers on. As soon as I did this I heard this loud rattling that seemed to be caused by the exhaust. Basically it sounds like a bracket is loose and every so often it sounds like the exhaust is rubbing against the body (doesn't happen if I sit there and rev it.) but does happen while in motion.
Anyway, I realized some of the hanging brackets were loose, so I tightened them up and I thought the sound was gone but I keep hearing it ; just fainter. I had my 40 series flowmasters put on and the sound is still there. I looked all over the exhaust and there doesn't seem to be anything touching. Could it be the jack rattling against the body? I took the spare out and the jack didn't seem to be really "secured" to anything. Can someone send me a picture of the proper way the jack is supposed to be? I was looking at the little diagram on how the Jack is supposed to be removed but mine isn't located like that. I tried to reposition mine to match the diagram but it still didn't work... So if someone could snap a picture of theirs that would be greatly appreciated. Thanks.
Any other ideas on what it could be would help as well.
Old Jul 29, 2007 | 12:58 PM
hammeron's Avatar
hammeron
Default RE: Something rubbing/rattling into the underbody.
it's not a great pic and i'm not even sure
the jack is in the correct posistion, but
this is how mine is.
found a better pic...
[IMG]local://upfiles/37808/96B379C357454736B59BC6635102B95E.jpg[/IMG]
Old Jul 29, 2007 | 01:09 PM
mlcrycc's Avatar
mlcrycc
I spent hours yesterday trying to find the source of my "2500 RPM" squeal, rattle, noise, screech, whatever...". Still there. Tighted everything on the exhaust, hangers, over axle pipe, clamps, everything...Still there. But it does now do it while not moving, so I have pretty much ruled out the clutch paks....Still might be one of my Flows starting to go bad....Don't know...
I thought I had found the issue with one of the Cat heat shields on the drivers side. Very vibratory, but I bent it so it wasn't vibrating, to no avail. You may want to check this heat shield on the drivers side, right below the drivers seat...
Mike
Old Jul 30, 2007 | 09:03 AM
Menace's Avatar
Menace
ORIGINAL: mlcrycc
Mike
No, it's definately coming from the rear of the car. Only happened when I took off my SLP Loudmouths and put the stock exhaust on so I'm sure it has something to do with the exhaust. Basically it sounds like the exhaust is making something along the lines vibrate into the body. I just can't locate it.
Today I'm just going to take out the jack all together and see if that's the problem. Looking at your picture it's very angled and not centered over those two things. Though you have that little hook screwed through the jack handle and into the body which mine doesn't have. (It has the screw, just wasn't screwed through the jack.)
Old Jul 30, 2007 | 11:55 AM
ilmor's Avatar
ilmor
Hope you find the cause - I know, these things can really drive one nuts.
Couldn't help but notice you sig! You ran13.075 @ 107.75 mph with a bone-stock GT??? [:-] Tell us more!!
Old Jul 30, 2007 | 12:07 PM
Nuke's Avatar
Nuke
Check the insertion depth of the mounting "finger" in the hanger at the rear of the muffler. It's possible that your reinstall has the finger a little closer to the frame than when originally installed and engine movement and exhaust system expansion when hot is allowing it to make metal-to-metal contact.
Rick
[sm=smiley34.gif]
Old Jul 30, 2007 | 12:56 PM
Dex's Avatar
Dex
ORIGINAL: mlcrycc
It sound kinda metallic?
Old Jul 30, 2007 | 01:19 PM
mlcrycc's Avatar
mlcrycc
ORIGINAL: Dex
ORIGINAL: mlcrycc
Yep. Sounds like a kazoo......I had one of my co-workers verify this morning for me. It's the driver's side Flowmaster....[:@][:@] It only hits right at 2500 RPM, on both accel and decel.....I guess I thought that when the Flowmasters took a crap, it was all at once, and all the time....Guess I was wrong....[:'(][:'(]
Mike
Old Jul 30, 2007 | 01:41 PM
Dex's Avatar
Dex
well i get the noise at 2500rpm's but i dont have any new exhaust in. dont know what it is but sometimes it gets really annoying hearing it.
NeoTokyo
Mar 7, 2012 10:39 PM
dealrocker
Jan 15, 2010 01:53 PM
AmericanMuscle4.6GT
Jan 19, 2009 01:49 PM
kazzepink
Sep 24, 2007 06:09 PM
jaxbelleil
Jun 5, 2007 10:58 PM
