XCAL 2 doesn't work!!
Old Aug 5, 2007 | 09:55 AM
  #31
markiemark's Avatar
markiemark
Default RE: XCAL 2 doesn't work!!
Sorry the response above ended up in the quote!!!
Old Aug 5, 2007 | 11:19 AM
  #32
markiemark's Avatar
markiemark
O.K> I checked all the connections and the 1 on the intake tube wasn't locked in and I also need to put 93 octane for it to clear up. I drove it and the only problem I see is that the speedo is off. Other than that I'll give you an update when the gas is in!!!!
Old Aug 5, 2007 | 12:47 PM
  #33
howarmat's Avatar
howarmat
s197 Junkie
ORIGINAL: markiemark
ORIGINAL: PLstang
I'm gonna go with the gas agian. Sounds like the tune is installed. It appears you have everything hooked up. It sounds like it takes a few minutes before the light comes on. That or when you start to excelerate. It may be the gas and the only way to know is well go back to stock and run out the old gas. Then you can fill her up with 93. You only have half a tank of 93 at the moment (I think thats what i read). What did you have in it before then and are you sure it was only half a tank before you refilled to 93?
I'm running like 89 octane right now. Maybe it's just that. I'm gonna give it a shot and return to stock and replace with stock intake. Then run that crap gas out and fill with 93. Hopefully that does it. Thanks.
That is the problem right there probably......you should never run a higher octance with lower octane in the tank.....
MustangGirl98
Aug 2, 2016 08:10 AM
67LimeCoupe
Nov 25, 2015 08:55 PM
MusicCity615
Sep 27, 2015 12:53 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
Sep 1, 2015 08:16 PM
