XCAL 2 doesn't work!!
Old Aug 4, 2007 | 09:12 AM
markiemark's Avatar
markiemark
Default XCAL 2 doesn't work!!
I got an Excal2 and a JLT intake from a forum member in perfect condition and unlocked. I installed the intake and plugged in the programmer and it says wrong vehicle. It's a brenspeed so what do I do now? Can I still drive the car? How do I get it reprogrammed? Thanks.
Old Aug 4, 2007 | 09:15 AM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
Default RE: XCAL 2 doesn't work!!
It sounds like it's still married to the other vehicle in which you bought it from. Don't drive it with the JLT on it without a tune in it.
Old Aug 4, 2007 | 09:16 AM
schapman's Avatar
schapman
you need to call a tuner(brenspeed, ETC) and have them send you a tune coded to your ECU number. U can find your code on the passenger site of the engine bay tords the front . look for a silver box close to wher the headlight stops. sorry i dont have a picture.
Old Aug 4, 2007 | 04:37 PM
markiemark's Avatar
markiemark
Thanks. I called brenspeed and it turns out the tuner was for a 2007. Thanks Viridian who sold it to me....Anyway I received a 93 octane tune for $ and uploaded it successfully and loaded it into the car. It took a few times but I did it and now the wrench symbol is on and I'm screwed! Tried a few things and no good. Any suggestions at this point?
Old Aug 4, 2007 | 05:19 PM
06GT4RAD's Avatar
06GT4RAD
Not that this helps you any but this is why i would never buy a used tuner. I cannot even count how many times I have seen this happen to people.
It simply is not worth the headaches that can be created. Does the car run? Have you scanned the ECM to see what codes are stored?
That could help determine the issue
Richard
Old Aug 4, 2007 | 06:44 PM
markiemark's Avatar
markiemark
ORIGINAL: 06GT4RAD
Richard
Ur right! I should have gone new...Oh well! Yes the car runs but the wrench symbol is on and I don't want to drive it. + the intake is in and I was told not to drive it without a tune, which is not working....
Old Aug 4, 2007 | 06:52 PM
mlcrycc's Avatar
mlcrycc
So when you spoke to Brent, did he ask you for your ECU number, as noted above? Also, you said it took a few times to load it....what exactly prevented you from being able to load it first try???
Mike
Old Aug 4, 2007 | 07:25 PM
hammeron's Avatar
hammeron
ok, i have to ask. is it possible you
have ANY lower grade octane fuel in
the system?
i'm not sure, but maybe the wrench symbol
is for a knock detection (pinging)
you would not want to run the 93 tune unless you
have 100% 93 octane in your fuel system
ORIGINAL: markiemark
Old Aug 4, 2007 | 07:26 PM
s197richie's Avatar
s197richie
I ♥ Acer
ORIGINAL: 06GT4RAD
Richard
+1...used performance parts = giant pain in the ball$
Old Aug 5, 2007 | 08:25 AM
markiemark's Avatar
markiemark
ORIGINAL: mlcrycc
Mike
First try it said Pwrup msg time out or something like that. But then I started again and went through the ques. load tune 93 octane and then it said adj. parameters and I cancelled it to use stock tune which in my sitiuation is 93 octane. when it finished I unplugged it, started the car and started driving not even 100 feet and the wrench symbol comes on.
