what d/s to get
Old Aug 7, 2007 | 01:56 PM
Sherwood06GT's Avatar
Sherwood06GT
Default RE: what d/s to get
ORIGINAL: scramblr
d/s = Driveshaft.
Sherwood06GT - I'm obviously a supporter of BMR, hell, most of their suspension parts are under my car, but $1100 for a DS? Bit expensive...but of course that's relative. :-D Oh and it's not on their site anymore...did they discontinue them? Just wondering.
http://www.lmperformance.com/5996/73.html
Sure it is expensive. It is rated to over 1000 HP and WILL NOT BREAK. It is also very light. IMO the best.
Old Aug 7, 2007 | 02:11 PM
scramblr's Avatar
scramblr
Granted, but the driveline will start to give at 600+ and the DS will be the least of a persons worries. But you're right, if running that kind of hps with a bullet proof driveline, can't go wrong with the BMR DS. I saw it in the LMP site as well, just weird BMR pulled it off theirs.
Old Aug 7, 2007 | 02:15 PM
zkiller's Avatar
zkiller
Powerhouse has a great 4" aluminum driveshaft. I have 8000 miles on mine and it has never clunked or vibrated in that time. I have tested it to 160+ MPH.
The thing to look for is a driveshaft that does not require you to change the pinion flange. The Powerhouse uses and adapter that lets you keep the original flange.
Old Aug 7, 2007 | 02:47 PM
Newbreedgt05's Avatar
Newbreedgt05
ORIGINAL: zkiller
Actually the driveshafts that require you to change the pinion flange have less vibration and problems then others that use the adapter. I have the spydershaft and that comes with a new pinion flange. There are no vibration problems with any of Spyder's driveshafts. I lost count of how many people had problems when they used an adapter to install their's. If the adapter isn't installed perfectly, there will be vibration at higher speeds.
Old Aug 7, 2007 | 02:49 PM
scramblr's Avatar
scramblr
ORIGINAL: zkiller
I have to disagree. Why use an adaptor for a rear flange that was designed for a CV joint not a U joint? Granted, most of them work with the adaptor, but if the DS has a U joint, why not have a rear flange that marries up to it like it's supposed to? Why haven't all these DS manufacturers built them with CV joints? Myself and quite a few others have gone through hell and back becauseof this. Switched to the Spyder and a new rear flange and the vibrations are gone. It is a crap shoot from car to car and the adaptor plate. Install was not an issue with mine since I did it 6 seperate times under strict guidelines from the manufacturer and I still had panel ejecting vibrations. I'm just glad that my issues and many others were solved with the correct type of flange.
Old Aug 7, 2007 | 03:09 PM
Sherwood06GT
ORIGINAL: scramblr
ORIGINAL: zkiller
Hence:
BMR's carbon fiber driveshaft comes with a new billet 4340 pinion yoke and a billet 7075 front flange both using heavy duty 1350 series u-joints. The carbon used in these shafts has two distinct wind angles to provide the most unparalleled torsional rigidity(45 degree wind angle) without sacrificing linear strength(15 degree wind angle). NOTE: Rear pinion flange requires professional installation.
Old Aug 7, 2007 | 03:54 PM
brendend's Avatar
brendend
thanks alot for all the input, just ordered the spyder d/s. cant wait to get it in.
Old Aug 8, 2007 | 12:56 PM
Timmay!!!'s Avatar
Timmay!!!
Unless you putting down something crazy like 1000 rwtq the shaft itself won't usuallybreak, its the U-joints that give in. I think I've seen one D/S that was twisted up ever.
ryanralston07
Sep 4, 2008 03:19 PM
Jsierzega
Jan 31, 2008 11:18 PM
acstone7
Aug 28, 2007 08:57 PM
JimboGT01
Jul 2, 2007 03:10 PM
brendend
Jun 18, 2007 12:55 PM
