mole skind and royal purple syncromax
i just installed moleskin on my windows... really really easy... just follow tacobills guide in the sticky section
i also changed my tranny fluid to the Royal Purple Synchromax... this is a MUST DO! I can barely hear the tranny now... a little in first... but thats it! I followed the methods of someone in here to go through the center console with tubing... I didnt remove the entire center console, jsut the shift boot and pushed the 1/4 inch tubing through the hole for the shifter... worked like a dream... only one drop was spilled, onto a towel luckily... definitely something anyone can do
RE: mole skind and royal purple syncromax
Mike
Someone mentioned before about removing the shifter stuff and dropping some tubing down through there and then fill it that way.....i agree this would probably be much faster
howarmat... thanks... i looked earlier... but kept getting a v6 thread about something else... had a hard time finding that one...
i did buy 4 quarts... but it only takes 3.2... i just had my buddy dump the first three in and then i measured it with a zip tie bent at a 90 degree angle until it was at the right spot... according to the manual it needs to be 1/2" below the fill hole... it cost me around 50 bucks... new drain pan, tubing, 4 qts of fluid, and some permatex....
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
