Saving Gas Mileage in a manual by using the stick...
#82
RE: Saving Gas Mileage in a manual by using the stick...
ORIGINAL: iluvmycar
Having a debate with someone...
So heres the question... is it better on gas to keep the car in a low gear at high RPMs or at a high gear on low rpms for gas mileage?
OR... neither... keep it medium...
Say... keep her in 4th gear at about 40mph instead of 3rd... or say 5th....
I say keep her in 4th at that speed...
3rd maybe to high RPMs on gas... 5th.. you are wasting gas trying to keep it running at that low RPM....
Sooo ... I'm right.... right?
Low RPM is best but it also depends on a number of other factors.
Low RPM going uphill means you're porbably going to be floored on the gas to maintain speed thus you'll be blowing through fuel. High RPM on a downhill means you'll be wasting gas when you could just be coasting.
And coasting uses the LEAST amount of gas.
BeatnikFink
10-01-2015 08:00 PM
