Please explain
Old Aug 16, 2007 | 04:57 PM
TJ's Avatar
TJ
Default RE: Please explain
ORIGINAL: wyldwmn65
I am having a problem with the offset. I am trying to stay in the 40-45mm range as you suggested, but every wheel I like is a 35mm offset, would that work or is that too much of a difference. I have been looking at a 20inch with 8.5inch width.
In my previous post I suggested stay as close to 40mm as you can (38mm is close to 40 example)some wheels come 28 mm 34 mm etc,AmericanMusclerims are made for 05-08's and I think all thier rims are 45mm with the exception of the DD 38mm (I think) they are do to the DD. You can use other MM but I would try to stay as close to 40 as you can you don't want the rim sticking out of the wheel well very sad looking imo. Find the rim you like if it is local and and have them put one on to spec it if the MM is low
Old Aug 16, 2007 | 07:43 PM
wyldwmn65's Avatar
wyldwmn65
Thank you all so much for your help. This can be quite overwhelming.LOL
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
mrappe
Sep 26, 2015 10:16 AM
bikerdoc
Aug 25, 2015 06:46 AM
ccwebb
Aug 11, 2015 06:47 PM
