Oil Fill Tube
Old Aug 18, 2007 | 12:45 PM
rfelger's Avatar
rfelger
Default Oil Fill Tube
HI, anyone know how to remove the plastic fill tube between the oil cap and valve cover?
Old Aug 18, 2007 | 12:47 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Oil Fill Tube
release the fittings and pull
Old Aug 18, 2007 | 01:31 PM
FlaPony's Avatar
FlaPony
Removing the spout is a bit tricky. There is a tab that must be pushed down and then the spout is removed by turning counterclockwise. Don’t be afraid to use some force, you will actually need quite a bit of force to remove it. There will be a loud click and then the spout just pops off.
Old Aug 18, 2007 | 01:40 PM
doctorstrobe's Avatar
doctorstrobe
I broke the fill tube when I removed mine.
I didn't know there was a locking tab inside and the only instructions I had said to turn it hard...
Afterwards I saw that I should have gone in from the inside of the valve cover with a small screwdriver and lifted that plastic tab while I turned it.
If you DO break the fill tube you don't really need to replace it. The oil fill cap will lock right into the valve cover itself.
I like it better without the fill tube.
Old Aug 18, 2007 | 05:06 PM
drbobvs's Avatar
drbobvs
+1 I broke mine too. I still can use it, but the look of the cap directly on the valve cover is better.
Old Aug 19, 2007 | 01:29 AM
StantheMan's Avatar
StantheMan
Doctorstobe, Awesome job on the side stripes, looks real good!
Old Aug 19, 2007 | 06:15 AM
doctorstrobe
ORIGINAL: StantheMan
Hi, Thanks. Those are Graphics Express vinyl stripes.
Sometimes I think it might look too 'race car' though... Like just slap a number on the side and get it over with... [8D]
Old Aug 19, 2007 | 07:01 AM
MantaDreams's Avatar
MantaDreams
ORIGINAL: doctorstrobe
also, very nice work on the valve covers. well I'll say yours is the best lookin yeller car i've seen yet.
u have something going on in your engine bay from the photo?
Old Aug 19, 2007 | 07:57 AM
doctorstrobe
[/quote]
[/quote]
Yes, that was from when I was installing the Whipple SC.
Old Aug 19, 2007 | 09:40 AM
1BADD05's Avatar
1BADD05
Yes u have to use a small screwdriver and release the locking tab and turn, I have to say I have never seen a car without it, but Damn thats looks great man! Good Job!
jwog666
Dec 27, 2021 08:09 PM
daltron
Apr 28, 2016 08:10 PM
wraith777
Sep 28, 2015 10:49 AM
GLOCKer
Sep 28, 2015 07:36 AM
zachary1988
Sep 4, 2015 03:04 PM
