wheel studs
Old Aug 18, 2007 | 02:25 PM
rojizostang's Avatar
rojizostang
Default wheel studs
I installed a set of the 1" hub centric spacers on the rear of my 07gt. To make a long story short, I don't like them. The stock 235/50/18's are too close to the edge of the fender for my taste. So the question is can I replace the stock wheel studs without pulling the axles? (I had to cut the studs to install the spacers)
I'll probably go with a set of 3/4" spacers, but I'll need a little longer stud than stock for this set up. I don't have a problem with spacers, so let's skip the "you shouldn't run spacers" comments, thanks.
I'll probably be selling the 1" spacers if anyone is interested. They're hub centric to the hub and wheels. Email me at rojizo41@hotmail.com if you're interested.
Old Aug 18, 2007 | 04:10 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: wheel studs
The manual shows using a ford tool to remove the studs.
It shows it being done on the vehicle but its easier if you
remove the axles and hubs. You gots the tool for on vehicle
replacement? If not, its axle/hub removal time.[:@]
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
