Tire sizes
Old Aug 20, 2007 | 04:43 AM
Stkjock's Avatar
Stkjock
Retired Mod
Default RE: Tire sizes
gee Stoenr.... isnt it 17 years with goodyear? good greif man.... by now you gotta be an expert!!!
Old Aug 20, 2007 | 09:20 AM
Gaspi101's Avatar
Gaspi101
Anyone have a straight answer? How about just a yes or a no. Can I fit a 265/45/17 on a 17x8.0 rim?
Old Aug 20, 2007 | 01:37 PM
Stoenr's Avatar
Stoenr
Yes, you can
Old Aug 20, 2007 | 01:41 PM
Gaspi101's Avatar
Gaspi101
Awesome. Thanks. And why is it that it's not "recommended"?
Old Aug 20, 2007 | 01:43 PM
Dex's Avatar
Dex
i wouldnt do over 255 on a 8 inch rim.
Old Aug 20, 2007 | 01:52 PM
Mikes_BLK_GT's Avatar
Mikes_BLK_GT
Its pointless your likely to have the tread just roll over and become sidewall because they have to shoehorn the damn tire onto the rim. If you want bigger tires you need bigger rims IMO.
I'd agree with the 255/45/18's on the 18x8.5" wheel and have heard 275/40/18 for 18x9's.
Old Aug 20, 2007 | 02:43 PM
Gaspi101's Avatar
Gaspi101
ORIGINAL: Dex
Why not?
Old Aug 20, 2007 | 02:45 PM
Gaspi101's Avatar
Gaspi101
ORIGINAL: Mikes_BLK_GT
Are you saying that there is not enough room in the wheel well to put a "shoehorned" tire? i thought all tires were "shoehorned" in. What do you mean?
Old Aug 20, 2007 | 04:09 PM
Stoenr's Avatar
Stoenr
To much sidewall flex. I run 275/40/17 Drag radials on the Stock 8" rim, but dont drive them to the track, I install there. Too small diameter, pluss too much sidewall flex. You will lose handling with a tire thats too wide for the rim.
Old Aug 20, 2007 | 04:32 PM
dseid2's Avatar
dseid2
Check out this site http://www.1010tires.com/TireSizeCalculator.asp. Plug in your current tire size and your desired tire size and it tells you if it will work and the rim width necessary
According to this site your best bet on 17 X 8.0's is a 255/50/17. This size tire will actually improve your gear ratio.According to this web site, it is also okayto275/50/17 on your current 8.0 rims, but the diameter of this tire is bigger so you will lose gear ratio. For those of you reading this post with 18 X 8.5, this siterecommends 9.0 inch wide rimesto run the 275/40/18. I would assume this is because the 275/50/17's have a taller profile to spread the extra width over. Personally, I set my highly modified suspension up for a street/road race application,so I run 255/45/18's. One can always through on a set of drag radials at the drag strip.
[IMG]local://upfiles/63299/C5C8D2F342A443F4965720FA92AC299E.jpg[/IMG]
