LOST MUSTANG KEYS, ADVISE PLEASE
Old Aug 21, 2007 | 11:35 AM
Drop Top 06's Avatar
Drop Top 06
Default RE: LOST MUSTANG KEYS, ADVISE PLEASE
I actually keep one set of keys in a safe... Although, if i forget the code, I'm in big trouble. You never did fess up as to what happened to the other set?
Old Aug 21, 2007 | 11:38 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Drop Top 06
You still need two programmed keys to program.
Loose one set and thats all you got left is one set.
No way to program any more unless the dealer
does it for many $$s. You really need two sets
in your safe to be safe from dealer charges.
The key # is on the ign. cyl. behind the steering
wheel plastic trim also.
+1 fess up
Old Aug 21, 2007 | 05:59 PM
D_Gusler's Avatar
D_Gusler
you will need two keys in order to program them.
Pats keys retail for around $15 each, and we charge a half hour to program the keys(our labor rate is $65/hr) so for two keys & program, it is around $65 total.
Do not get charged more than half an hour for labor. It takes only 15 minutes to program the keys.
Old Aug 21, 2007 | 06:05 PM
D_Gusler's Avatar
D_Gusler
EDIT:
Also you will need to add in the cost it takes to get youre car towed in to the dealer.
Old Aug 21, 2007 | 07:54 PM
PROMETHEUS PRIME's Avatar
PROMETHEUS PRIME
You can get away with only programming 1 key if they do spare key program. But if done in this way any key lost will still start the car.
MEISTERSNFB
Mar 31, 2020 07:50 AM
raven_ghostwolf
Aug 16, 2015 08:16 PM
mweiland
Aug 16, 2015 10:59 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
daytooday
Aug 11, 2015 09:22 AM
