Rust build up on rotors. UGH!!!
Old Aug 22, 2007 | 11:03 AM
  #21
kamakazitp's Avatar
kamakazitp
Default RE: Rust build up on rotors. UGH!!!
The place where rust will eventually show up that you won't be able to get rid of is the very edge of your contact areas. As this slowly spreads, it will get farther and farther away from the brake pad such that the pad won't be able to knock it off when you drive.
The best way to prevent this is by not letting the brakes sit with rust on them for very long. So if you aren't driving your car for 2 weeks, and the rust just sits there, any moisture in the air will allow the rust to spread, so take it around the block, knock off the rust, and try to keep it away from the moisture.
Old Aug 22, 2007 | 11:15 AM
  #22
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: edgespeeder06
how about a brake shield cover? im thinkin of getting one because its looks even more worse with my summer 20s, really hate it...and also hate the dust that the chromes get right away so brake or dust shields would be nice.....where can i get it?
MossMustang has em.
Old Aug 22, 2007 | 04:45 PM
  #23
edgespeeder06's Avatar
edgespeeder06
oh wow thats good thanks! i'll check it out, i wonder how it looks with them on, anyone have pictures?
just checked and they only have it for my winter rims, not these which i would like them for.
Old Aug 22, 2007 | 05:04 PM
  #24
SanJose06GTVert's Avatar
SanJose06GTVert
spray the rotors with WD40
Old Aug 22, 2007 | 05:42 PM
  #25
281GT's Avatar
281GT
It's a fact of life. Every car on the face of the planet does this. Exposed metal is going to have surface oxidation when it encounters moisture. Move the desert or live with it.
b8checker
Oct 8, 2015 12:55 PM
Oct 7, 2015 07:02 PM
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
b8checker
Sep 30, 2015 07:11 AM
