Must haves if a blower is added?
RE: Must haves if a blower is added?
A week into a blower I can tell you that new springs are on my short list. Or rather, a complete overhaul on the handling. This car was built to be a compromise between the stock HP and give what would be still *perceived* as decent road manners so Joe Public would still buy them.
Throwing in a Whipple has tossed that all out the door. The back end is in the pavement onmoderate acceleration.
Regardless, there is no reason you can't put in a S/C NOW and tweak after. As far as I am concerned, there is no "must do in conjunction with" components...
I've got a couple of exterior mods I wanna get knocked outta the way first but then I'll be going after suspension,
then brakes,
then back to upping the power,
then to...[8D]
then brakes,
then to...[8D]
It'll be awhile before I get a S/C but before I do I plan the following
Exhaust (headers, crossover, and mufflers)
diff
(Rims andtires) 295 rear
suspension (LCA and maybe UCA) I don't want to lower it
ignition (MSD Coil on Plugs)
maybe a few other things
as I said it'll be awhile before I do any of this
diff
and.......... not a must have, but wouldn't keeping my gear ratio at 3:55 until my suspension is beefed up be better off then going to 3:73 or 3:90 right away? I wouldn't have as much torque so should be a little easier on the suspension......??
