Gear shift vibrations
Old Sep 5, 2007 | 01:07 PM
owero01's Avatar
owero01
Default RE: Gear shift vibrations
I just developed the same problem. I'm taking it to my mechanic this week. It happens when I'm WOT in the lower gears.
Old Sep 5, 2007 | 02:08 PM
CG07GT's Avatar
CG07GT
sounds about like the same problems I am haveing
Old Sep 5, 2007 | 04:24 PM
DUNC's Avatar
DUNC
Same here, shifter vibration/ rattle at around 3000 rpms in 2nd and 3rd gear under moderate to heavy throttle. Drives me nuts.
Please post up what your dealer says, mine said "normal operation". Gee, thanks.
Old Sep 5, 2007 | 05:03 PM
moosestang's Avatar
moosestang
Mine does this in 3rd gear. If I hold up on the shifter it will stop. Is this what everyone is talking about? I first thought it was the hurst ball, but i'm pretty sure it's the shift linkage and probably normal, unfortunately. I just keep my hand on the shifter and apply a little pressure, problem solved.
Old Sep 7, 2007 | 08:41 AM
DUNC's Avatar
DUNC
bump for more feedback.
Old Sep 7, 2007 | 02:40 PM
kovar's Avatar
kovar
I have the same problem esp. in 3rd gear -- mostly when decelerating. While accelerating, rarely appears to be an issue, but as soon as I left off the gas, the feedback through the handle begins.
Old Sep 7, 2007 | 03:51 PM
DocVenture's Avatar
DocVenture
Mine does 3rd and 5th
4cylinderplus2
Oct 9, 2020 07:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
Explosive
Oct 2, 2015 07:45 AM
