rust starting to show
Old Sep 6, 2007 | 01:07 AM
UAE_Muscle's Avatar
UAE_Muscle
Default rust starting to show
went to the carwash today and as the guy who works there lifts my car up i notice several parts are starting to rust! even though temperatures in my area are 3 digitsi was surprised as my mustang is one month old now so its relativly new.
Do you know any products that can stop rusting?
Old Sep 6, 2007 | 07:54 AM
CorruptedDemon60's Avatar
CorruptedDemon60
Default RE: rust starting to show
You could always rattle can the entire bottom of the car with that rust preventer stuff. It comes out black in color.
Old Sep 6, 2007 | 08:07 AM
pascal's Avatar
pascal
S197 Section Modder-ator
ORIGINAL: UAE_Muscle
POR 15 is a brushable product that is better applied on surface rust (google it). No need to clean metal to a shine finish. Wire brush as much as you can and put that stuff on directly. 2 coats are best.
The down side : Don't get any on you, it's real hard to clean. It dries very slowly and the shelf life is short after opening.
When this stuff is dry, you'll need a chisel to take it off! It won't sand very good.
Old Sep 6, 2007 | 08:48 AM
CataclysmGT's Avatar
CataclysmGT
A thin layer of rust on metal components (axle / diff etc) will actually prevent further corrosion. One really should only be concerned with body panels, unless you want to keep the car for 20 years.
Old Sep 6, 2007 | 09:50 AM
marcuskeeler's Avatar
marcuskeeler
|Even tho mine is a summer car I've been contemplating getting mine rust proofed withoil, the service is pretty widely available. I've had my DD and my wifes car done and it really makes the underside shine as well as damping down the rust and keeping things like brake lines and linkages in good order. The oil is pretty much clear so doesn't make the thing look nasty and they do the inside of the rocker panels, doors and all that stuff.
Oil is much preferrable to the other wax based products as it creeps around the metal work naturally unlike wax which sticks where it touches leaving shadowed areas exposed.
Old Sep 6, 2007 | 09:53 AM
acascianelli's Avatar
acascianelli
Many components on mine are covered in surface rust already. I don't see it as being a big deal.
Old Sep 6, 2007 | 10:58 AM
WALLACE's Avatar
WALLACE
unfortunately,this is normal for these cars and not a big deal. i've owned several mustangs
and its common to have surface rust.
Old Sep 6, 2007 | 11:09 AM
thewarmachine's Avatar
thewarmachine
Cataclysm, where are those black saleens? I'm anxious to see them on your car. My chrome CT-R's come in tomorrow.
Ok, just so this is not completely off topic....Yes, my stang has underside rust too....even my water pump is all rusted over. It's not a show car, so I don't really care.
Old Sep 6, 2007 | 11:50 AM
Nuke's Avatar
Nuke
Beware undercoatings! They can retain moisture and cause more damage than they're supposed to prevent.
Old Sep 6, 2007 | 04:35 PM
pascal's Avatar
pascal
Isn't it sad that Ford don't paint anything underneath that's thick metal? Steering boxes (my F150), drive shafts, rear axle housings, leaf spring, spindles etc... It safe cause it won't rust through anytime soon but it looks like s@#t.
And for those of youwho drive these cars up north in the winter, what a mess!
