rust starting to show
#21
RE: rust starting to show
ORIGINAL: STORMEASTON
That has to be the dumbest thing yet I've heard on these forums, undercoating is sealant not a sponge! The only way it could trap moisture is ifit was applied when the car was wet, which I'm sure would not happen!I just got done taking the body off a 1967 Galaxie 500, a 40 year old car, the only places that had rust on them were...tada, the spots where they didn't apply the undercoating to. And I might add that stuff is a real bugger to get off metal surfaces!
ORIGINAL: Nuke
Beware undercoatings! They can retain moisture and cause more damage than they're supposed to prevent.
Yes, I have seen surface rust under my car when it was on a lift. The guys at the shop pointed it out to me and said, a car (at that time) only 8 months old should not have rust on it like that.
Eventually I want to switch out the driveshaft and get an aluminum one.
#22
ORIGINAL: marcuskeeler
Like I say, get the oil underspray treatment, it's cheap, cost me $110, and it makes the underside look awesome as well as Protecting it.
jpplaw
08-22-2015 09:29 PM
