ANOTHER NEW PROBLEM...Speedometer!
Old Sep 10, 2007 | 02:23 PM
05MustangSally's Avatar
05MustangSally
Default ANOTHER NEW PROBLEM...Speedometer!
Hi Guys!
I haven't taken my car in yet to get the fuel level sensor replaced. That comes tomorrow... But this morning, I had another issue with the Stang. On my way to work, the speedometer stops working. First it drops to 0 while I'm driving, then it will every-so-often come back up but it won't read accurately when it does. Anyone else have this problem? I wondering if it's common...I just want to make sure the dealer fixes it with no excuses. [:@]
Thanks!
Old Sep 10, 2007 | 02:30 PM
DeStonn's Avatar
DeStonn
Default RE: ANOTHER NEW PROBLEM...Speedometer!
Never had that issue with mine but I wish you luck. Let us know what the stealership says is the problem.
Old Sep 10, 2007 | 02:31 PM
steveo555's Avatar
steveo555
Low battery? My dads 2006 Mustang turned the speedometer, A/C, radio, and windows off a few minutes before the battery died. Whats is the fuel level sensor problem? sometimes my 2007 Stang reads less then 50 miles to empty when its a full tank of gas.
Old Sep 10, 2007 | 02:42 PM
05MustangSally
ORIGINAL: steveo555
Sure, I will keep everyone posted! I don't think it's a low battery. It took me 45 minutes to get to work and it started doing this right when I got on the freeway and didn't changed once I got to work. No problems with anything else electrical in the car either. The fuel level sensor problem Ihad was last week I had almost a full tank and the next day it said I was on E. No gas light came on or anything though. It's been fluctuating ever since. There is a TSB on it though so your warranty will cover it when you take it to the dealer. I would gets your's checked out too.
Old Sep 10, 2007 | 03:33 PM
Daniel60's Avatar
Daniel60
Yes mine broke too and it was replaced under my extended warranty. Thank God because it was a 500 dollar plus job. My car was made 09/2004. This month is her birthday.
Old Sep 10, 2007 | 06:36 PM
05MustangSally
ORIGINAL: Daniel60
YIKES! That's a lot of $$$ for something like that. Do you know what the problem was exactly when they fixed it? Just curious...thanks!
Old Sep 11, 2007 | 11:14 AM
05MustangSally
Bump
Old Sep 11, 2007 | 11:23 AM
bobNCSU's Avatar
bobNCSU
Most likely it is the vehicle speed sensor - my brother's Taurus was exhibiting the same symptoms, and it was about a $75 part which you just unhooked the wiring harness, and unscrewed directly from the tranny housing.
Hope that helps!
2006 Mustang GT | Black on Black | Manual | Stock
Old Sep 11, 2007 | 11:30 AM
urnamethere's Avatar
urnamethere
the same thing happend to me yestreday, i was going home from school it said i was going 0 MPH and at some points i would be going back in time, when i sped up it would go past the zero to about 20MPH but it was nowhere close to how fast i was going. i also had the fuel gauge pattern a while ago it kind of fixed itself, i was thinking maybe this would be a good time to upgrade to maybe a gt cintrument pannel with Mycolor, does anyone know if when they fix the problem witht the speedo and fuel gauge they have to replace the instrument cluster?
Old Sep 11, 2007 | 12:04 PM
05MustangSally
ORIGINAL: urnamethere
I'm curious about this as well. I would really like to have the 8 gauge cluster anyways...
The car goes in tomorrow morning, so Thursday morning I'll see what happens.
Thanks!
