Tire PSI
RE: Tire PSI
ORIGINAL: Dennis074.0
My tire PSI light came on. Does anyone know what PSI the pony package tires are supposed to be?
RE: Tire PSI
Well, that's way too low, but usually, the tire light will only come on when one or more tires differ significantly from the others like maybe 8# or so. Check your owner's manual to know for sure.
RE: Tire PSI
Thanks guys, I just went up and filled all four tires+spare, they were all running at 24psi, 25psi, 28psi, 23psi, and the spare was at 29psi.
I wanted to check the PSI about 2 weeks ago but couldnt find my psi reader, and then when the light came on today, I flipped my house and found it.
RE: Tire PSI
I run 32 PSI at the moment but will experiment up to 34 or 36. Since the Stang rides tight and harsh anyway, I may stay at 32 PSI since I use it mainly for road trips.
Remember, for every 10 degree change in ambient temperature you'll see roughly a 1 PSI change in tire pressure. I have a good digital guage and hand pump and I check mine often. I was down to 30.5 to 31 PSI now that the weather has cooled off a bit so I've been adjusting my pressure. I typically air up or down as the weather changes as much as 2-3 times per month. Guess I'm just ****...
Rick
[sm=smiley34.gif]
Rick
[sm=smiley34.gif]
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
