low tire pressure
low tire pressure
was driving down the highway the other day when all of a sudden a pic of a low tire came up on the tach side and a "low tire pressure" came on, so I pull over and do a walk around - everything looks fine, get home and check with a tire guage - 35 all-around - lights on dash still on. Any body have this problem? Thanx
RE: low tire pressure
I did have ours kick on the first day we got it after a really hard rain thought the sensor may had went out but no. it was just pressure was low. the manual said if the light stays on and pressure is good take it to the stealership, if you still have warranty... I believe it also said somethin about it needed to be cold tire pressure of 35 maybe check pressure again after the tire hascooled for a while
Read the owners manual.
Check your tire pressure.
Pressures OK =s trip to
the stealership to see whats
going on. Big temp change
recently? This will cause
sensor tripping as the pressure
decreases as temps decrease.
musnicki
09-23-2015 07:11 AM
09-08-2015 11:50 AM
