help at the track
Old Sep 23, 2007 | 08:31 PM
white531's Avatar
white531
Default RE: help at the track
cjponyparts don't have the market on 12:80's.They did it with a 05 which is down on power from the 07.
Old Sep 23, 2007 | 10:24 PM
ohfiveride's Avatar
ohfiveride
ORIGINAL: white531
ok you're killing me..so now youre saying 07 are more powerful than my 05....i just wanna know if you ran a 12.8 and what exactly you have done...and can you elaborate on the more powerful 07
Old Sep 23, 2007 | 10:46 PM
blackout's Avatar
blackout
ORIGINAL: white531
I have the same set up,and run 12.80 with the 3:31 gears.I am changing to 3:73 next week and hope to improve.I have been racing for 35 years and am comfortable with our track.I run my street tires 295-30-20,no water box,slight spin to clean the tires.Slip clutch till hook up and shift at 6200.Keep going to the track and having fun.Win or lose it's better than being in the stands.
I'm going to call bs, there is no way you are running 12.80 with street tires and just a CAI.
Whats your trap speed at along with some 60ft times? Even if you were powershifting 12.80 on street tires, I don't see that happening there champ.
Post some videos and a timeslip and some detailed pictures of your car. Even then I still won't believe you.
-Jeff
Old Oct 20, 2007 | 05:16 PM
mattstang2007's Avatar
mattstang2007
went to the track again. The best time I could get was 14.1. Here are the factors. Reaction time .43
60 foot 2.4
miles per hour 102.7
Only track prep was lowering tire pressureto 14 psion the stock tires.
I had a half a tank of gas and the engine was very warm between the c and h.
Only mods to the car is a cold air intack and a 93 octane tune from breenspeed.
I was launchingbetweens 2 and 2. 5 rpms.
If I let the engine cool all the way down and only had a little of a quarter of a tank how much time would it drop? Any other suggestions welcome.
Old Oct 20, 2007 | 05:21 PM
Ortoch's Avatar
Ortoch
practice dude you already droped half a second almost just get a feel for it and dont spin out, avoid the wet box like they said and drop it fast but dont spin on the take off.
oh and shift right before redline, with your tune and everything I would say right over 6000 RPMs will be your perfect shift point.
Old Oct 20, 2007 | 05:35 PM
moosestang's Avatar
moosestang
I feel like i'm taking crazy pills!! You could pull a better 60ft time by leaving at idle. Stop spinning your tires and don't lower the pressure to 14psi, that's probably not very safe.
ORIGINAL: mattstang2007
60 foot 2.4
Old Oct 20, 2007 | 06:06 PM
One Bad Stang's Avatar
One Bad Stang
leave your tires at recomended pressure, slip the clutch from 1800 rpm, and try not to spin the tires.
tires spinning=tires not pushing.
there are stock s197's (GT'S) at the track here running 13.5-13.9 all day long. STOCK!!!
you should hit at least a 13.3 with your mods.
Old Oct 20, 2007 | 06:08 PM
Ford_Dude's Avatar
Ford_Dude
did they (track crew) prep the track?
did you turn off TCS?
If your spinning off the line lower you launch RPM
don't mess with tire pressure YET (you should be able to break into the 13's without lowering tire pressure)
Have some one video the launch maybe by watching it we can help more
Mines a stockauto and I've done 13.9 so you should be able to getlow 13's
what is the altitude at the track
are you running with the sun out or at night (when the sun is out the track is warmer and thus stickier)
Old Oct 20, 2007 | 06:09 PM
One Bad Stang
ORIGINAL: moosestang
60 foot 2.4
14 psi is asking for permanent sidewall damage. radial tires dont work like bias-ply. they dont wrinkle on the sidewalls. that little ammount of pressure is probably slowing you down. if you absolutly dont want to take anyones advise and lower the pressures anyway, just put them at like 25+ psi
Old Oct 21, 2007 | 08:05 AM
mattstang2007
On my launches I didnt spin at all. It was cloudy overcast and probably 60 degress or so.
