antenna installation gone wrong
Old Oct 1, 2007 | 05:24 PM
  #21
PLstang's Avatar
PLstang
Default RE: antenna installation gone wrong
[:@] I hate when that happens!
Old Oct 1, 2007 | 05:31 PM
  #22
RED121572's Avatar
RED121572
Im sorry, but Ive had a few beam and cokes and in the mood to giggle. [sm=laughat.gif]
Old Oct 1, 2007 | 05:56 PM
  #23
Menace's Avatar
Menace
You aren't the only one. I got the 14" and tested the different attachments to see which one screwed into the car... Thought I found the right one, started screwing... Then went to tighten it and it spun right off and snapped inside. Went and got the screw extractor, got it out from the antenae but getting it out from the car was much more difficult. I ended up screwing the inside up and now nothing will fit there. I went to get a new one, but Ford says it's all one piece. Goes down the fender, along the block, and in through the firewall. The only disconnect is beneath the passenger dash. I could always try disconnecting it at the top and crimping the new one, but now I just think I want to get it removed and filled... Who knows.
Old Oct 1, 2007 | 06:28 PM
  #24
sleeper2's Avatar
sleeper2
So which brand/model shorty antennaes have been no problem? Does anyone have part #s? Thanks.
Sleeper2
Old Oct 1, 2007 | 09:23 PM
  #25
Aziraphale's Avatar
Aziraphale
My 14" from American Muscle came with a few adapters and I just picked the one that matched the stock threads. No problems.
http://www.americanmuscle.com/14in-antenna.html
Old Oct 2, 2007 | 07:29 AM
  #26
ink003's Avatar
ink003
i got mine from these guys:
http://cgi.ebay.com/ebaymotors/ws/eB...m=280153847792
they were quick to respond and quick to ship.the shorty didcome with an adapter, but went in like butter. no problems, and the antenaes come in different colors, too.
Old Oct 2, 2007 | 09:00 AM
  #27
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: pascal
Hey guys, don't be buying all kinds of tools to extract the remain of the antenna mast.
A new ant base retails for around $30.
How easy it it to install? Do you have to remove the fender?
Old Oct 2, 2007 | 09:02 AM
  #28
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Menace
They do make a "hidden" antenna that sticks to your windshield on the inside next to
the top and then the stocker can be removed and filled in.
Old Oct 2, 2007 | 11:09 AM
  #29
rom8bszfh2cg5q7s4pap's Avatar
To replace the antenna base, all you have to do is...
1) Remove passenger wheel and remove the back half of the wheel well plastic trim.
2) Remove antenna base cap, and remove the 3 screws that hold the base in place.
3) Detach antenna wire underneath glove box
4) Pull wire from out from wheel well, through the firewall
The new wire/base assembly has a grommet attached. So, all you have to do is feed the wire through the hole in the fender, and through the firewall. The entire process took me about a half hour. I would also purchase the antenna base cap, since you may damage it during removal. It's only a couple bucks.
Old Oct 2, 2007 | 11:16 AM
  #30
chupac's Avatar
chupac
I got my shorty from A/M and didn't have any trouble. I used the 8" for a while and cut my stock one to 14" to compare the two. I eventually ended up using the 14".
