antenna installation gone wrong
Old Sep 23, 2007 | 03:29 PM
sp00fs's Avatar
sp00fs
Default antenna installation gone wrong
I recently received my 8" shorty antenna.
I started by taking off the stock antenna. Then I started screwing in a (stud?).
As I was screwing in the stud, it broke off. So, the bottom half is stuck inside.
I was wondering what I should do at this point.
Help please!!
Old Sep 23, 2007 | 03:36 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: antenna installation gone wrong
WOW, never heard this before. Was it tough and tight going in?
Did you put sideways load on it and broke it or did it lock up
and twist off? Was the "stud" metal or aluminum. If it went in
tight and twisted off, drill it out and use a screw extractor? If
it went in loose and broke because of side load, try and coax
it out with a sharp insturment or a small screwdriver. Otherwise
you now havethe true "antenna delete" option with the base
still there.
wingman75's Avatar
wingman75
Go to Sears and buy a screw extractor. Here is a link describing them.
http://homerepair.about.com/od/inter..._extractor.htm
Old Sep 23, 2007 | 03:43 PM
sp00fs's Avatar
sp00fs
Thanks. On my way to Sears.
Old Sep 23, 2007 | 05:10 PM
Jackies Stang's Avatar
Jackies Stang
Some of the aftermarket ants. have different threads, hope you didnt cross thread the grommit! Easy out and check the threads! Good Luck!
Old Sep 23, 2007 | 06:43 PM
fairlane292's Avatar
fairlane292
Easy out is rarely "easy" out. Use the largest extractor you can... if you break one of these off inside then you have real problems... hardened steel does not drill out. ...be careful with the extractor.
Old Sep 23, 2007 | 07:34 PM
hammeron's Avatar
hammeron
this just happened to someone else, last week....
not sure how he got the broken screw out tho....
Old Sep 23, 2007 | 07:45 PM
TPony's Avatar
TPony
Ouch...that's going to be painful to extract w/o the right tools...
Old Sep 23, 2007 | 08:00 PM
Puckhog407's Avatar
Puckhog407
Is this common? I ask because I just ordered the black Billet 14" antenna and I just assumed it would be a 30 second, simple install.
Old Sep 23, 2007 | 08:28 PM
bl1nk's Avatar
bl1nk
ORIGINAL: Puckhog407
Its definately not common..... Mine actually took less than 30 seconds. And I thought a shorty antenna was pretty much the one single mod that NO ONE could screw up. I guess I was wrong. [&:]
