Idle problems solved!
Old Sep 23, 2007 | 08:44 PM
legend gt's Avatar
legend gt
Default Idle problems solved!
Just a heads up to all if you have experienced low idle or jerky type take-offs when cold.It was the throttle body! My 2005 GT finally threw a code after developing a low idle and it would act real jerky when it was cold taking off in 1st gear.Took it to the dealer and they put a new one on.Seems they have been replacing these alot here lately.Ford must have made some upgrades to them because the new part number is an 07' number.The mechanic told me the TPS usually goes bad.It runs a whole lot better now.Very smooth take off's and it idles around 900 rpm.It runs better than when it was new.Legend GT
Old Sep 23, 2007 | 09:31 PM
owero01's Avatar
owero01
Default RE: Idle problems solved!
Thanks for the info. Haven't had that problem yet.
Old Sep 23, 2007 | 10:07 PM
hammeron's Avatar
hammeron
it seems every week or so, another
part is failing
pretty soon the entire car will be a TSB
Old Sep 23, 2007 | 10:50 PM
sailing220's Avatar
sailing220
I had that problem - they told me the throttle body had cracked. They ordered a new one, put it on, cracked it again.
They ordered yet another one, this one with an '07 part number, and it has been fine since.
Old Sep 23, 2007 | 11:04 PM
ohnoesaz's Avatar
ohnoesaz
Does a new TPS or TB need any changes to the computer? Or is it just a straight swap?
TPony's Avatar
TPony
Thanks for the info partner.
Old Sep 24, 2007 | 01:33 AM
alloutt's Avatar
alloutt
is there anyway to make my break faster so I can get a new one?
Old Sep 24, 2007 | 01:12 PM
D_Gusler's Avatar
D_Gusler
There is a tsb on these dealing with the IAC. Ford says to replace these first, but like most techs, I just replaced the whole throttle body assembly. Just throwing out a cheaper option for those out of warranty.
mtgldr
Feb 3, 2024 09:00 PM
2007StangV6
Jan 28, 2016 06:09 PM
Golfsito
Oct 6, 2015 11:02 AM
96stang3.8
Sep 10, 2015 06:42 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
