doing lca's what kind?
Old Oct 5, 2007 | 01:57 PM
jwbrown21's Avatar
jwbrown21
Default doing lca's what kind?
I have the itch for some more mods and I cant bring myself to go 5k MORE in debt to supercharge right now. I figured I could start doing more on the suspension only problem is I dont know what all I need or where to go and get it? any suggestions?
Old Oct 5, 2007 | 02:15 PM
Sherwood06GT's Avatar
Sherwood06GT
Default RE: doing lca's what kind?
BMR
http://www.lmperformance.com
Old Oct 5, 2007 | 02:27 PM
28HopUp's Avatar
28HopUp
MF Administrator
If you plan to lower your car (or it is already), then buy adjustable LCA's (and a relocation bracket). My car has the stock springs, so I went withnonadjustable LCA's made by Evolution Performance (billet aluminum and have grease fittings) and a BMR adjustable UCA. The BMR piece is SOLID, so you wouldn't go wrong with BMR's top & bottom.
Old Oct 5, 2007 | 02:49 PM
torch red's Avatar
torch red
+1 BMR
ORIGINAL: Sherwood06GT
BMR
Old Oct 5, 2007 | 02:52 PM
ohsixgt1217's Avatar
ohsixgt1217
Spherical or poly?... or mix?
Old Oct 5, 2007 | 03:00 PM
DarkFireGT's Avatar
DarkFireGT
No need for adjustable lowers unless you're building a race car. Just get BMR tubular LCA's with poly bushings and relocation brackets if you're going to lower or change driveshafts. An adjustable upper with poly bushings would be good though.
Old Oct 5, 2007 | 10:05 PM
jerjan's Avatar
jerjan
BMR's are great. +1 on adjustable if you are going to lower with a one peice driveshaft.
Old Oct 6, 2007 | 11:51 AM
owero01's Avatar
owero01
Take a look at Spohn. They are of good quality and not that expensive.
Old Oct 6, 2007 | 12:05 PM
Caution's Avatar
Caution
I say BMR but I have heard good about Spohn too
Old Oct 6, 2007 | 12:10 PM
rshamekh's Avatar
rshamekh
F1Fan suggests Steeda, while CrazyAl prefers BMR ..
They are the best members suspension wise, but you got to decide which way to go.
F1Fan: https://mustangforums.com/fb.asp?m=3568309
CrazyAl: https://mustangforums.com/fb.asp?m=1700694
These are the most helpful threads about suspension on the forum, hope this helps.
