Head Lights stuck on.....
Old Oct 8, 2007 | 10:58 PM
allj's Avatar
allj
Default Head Lights stuck on.....
Something weird happened yesterday. I was going to bed and confirmed my car was locked. I hit the fob and all was well the horn honked etc. when to bed and noticed a few min later I see my lights are still on. I thought I was just a dumb a$$ and left the lights on for most of the night. I go outside and the lights were off. The light shut off when I unlocked the car with the fob.. Ok so i lock it again. Same thing. I get in the car start it and then shut it off get out and lock the car no lights.What is up???
Old Oct 8, 2007 | 11:02 PM
BlackonBlack07's Avatar
BlackonBlack07
Default RE: Lights stuck on.....
check the light dimmer behind the steering wheel to the left. its probably stuck on lights on. i did the same thing a while back just move it down and they should be back to normal
Old Oct 8, 2007 | 11:07 PM
hammeron's Avatar
hammeron
sounds like the smart junction
box, had an issue of some kind
hope everything is back to normal
now
Old Oct 8, 2007 | 11:41 PM
lrgnation's Avatar
lrgnation
Sometimes the switch can cause that, so can the sjb. I do not recall any TSB's on it so the next step is diagnosis. Pull out the dmm or take it the dealer if its under warranty.
Old Oct 9, 2007 | 08:57 AM
157dB's Avatar
157dB
Cut & Paste Expert
Check for the underdash water dispenser.
Is your carpet or pad wet on the frontpassengers side?
Old Oct 14, 2007 | 10:54 AM
allj's Avatar
allj
Default RE: Head Lights stuck on.....
Well it did it again last night. I tried to just lock the car and not use the fob. I locked it and when I shut the door the lights came on. It took the car for a drive at for about 3 min around the block parked it and it worked as expected. It rained yesterday so I was worried about the standard 2005 leak on the smart junction box. I took the cover off thesmart junction and felt under the carpet and it was dry. I will be making an appointment on Monday for the car to go visit the stealership.... Just another chance for the dealer and I to fight over the mods on the car....
Old Oct 14, 2007 | 10:59 AM
hammeron's Avatar
hammeron
sounding more like a sensor....
i think the stealership will be able to
diagnose and fix, pretty easily
MusicCity615
Sep 12, 2015 07:05 AM
zachary1988
Sep 4, 2015 03:04 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 04:12 PM
