Turbo Owners Chime In!
#31
RE: Turbo Owners Chime In!
ORIGINAL: androdz
Not wanting to bust ur bubble but a turbo at 8-9 psi is gonna make more power than ur s/c at 12 psi.
Andrew
Andrew
The whippled car producing those numbers belongs to Anthony05GT on M0dularfords.com.
#32
Themajor reason I went away from the supercharger route and opted for the turbo was the complaint I have seen from a few individuals on belts breaking or slipping...I really didn't want to deal with that issue at all...Plus the turbo power seems more limitless in that you can slap a bigger turbo on there, assuming you have the supporting engine and drive train mods and you can make a ton of power...
#33
ORIGINAL: Black05StangGT
How much boost do you ever see running, honestly? I wouldn't do more than pump gas can handle myself because race gas would be a huge hassle and expensive for me.
#34
ORIGINAL: moosestang
Not according to all the dyno numbers i've seen, but they weren't on the same car or done at the same time. A whipple with full exhaust has dynoed 534rwhp on 10.5psi, so if you could provide someone with a turbo making more than that at 8-9psi then I won't think you are blinded by your love for turbos.
ORIGINAL: androdz
Andrew
Andrew
Andrew
#35
All belt issues seem to be power shifting related and/or tensioner related. The bent/broken tensioner problem has been resolved though. I haven't broken a belt yet after 3k miles and a few missed shifts. I never power shift though, don't want a broken transmission. Anway Androdz constant argument that turbos produce more power doesn't seem to hold true at the psi levels he speaks of. I'm sure at higher boost it would, but not many will ever run over 15psi.
Also A big + that I like with the turbo is that with a digital boost controller you can control the boost you want the car to make on each gear to make it much more streetable and have a better launch. You can have 6psi on 1st, 10 on 2nd, 13 on 3rd, 18 or w/e on 4th. Or even better thave 6psi on 1st, 10 psi on on 2/3/4/5 and have a High boost button on your steering wheel that when you hit it goes to high boost setting. Would love to see something like that on a s/c what are they gonna do? have like 6 different belts? They have to make a waste gate for it to work.
Andrew
lincolnshibuya
12-08-2015 04:37 PM
