Need Mod Opinions $2500 to spend
Old Oct 27, 2007 | 10:14 PM
  #21
Gman13's Avatar
Gman13
Default RE: Need Mod Opinions $2500 to spend
thanks drbobvs. I like your suggestions, but from what I've read, should not go 4.10's if I'm going to supercharge. Did you do your drive shaft and UCA and LCA yourself?
Old Oct 27, 2007 | 10:16 PM
  #22
Gman13's Avatar
Gman13
ORIGINAL: howarmat
its pointless to get a GMS CAI if you are getting a tune, so get a JLT, C&L or Steeda.....
Already had the GMS CAI and just recently got a tune. Glad I did, it has made a big difference.
Old Oct 28, 2007 | 11:48 AM
  #23
Rubrignitz's Avatar
Rubrignitz
Ha! yeah, san marcos is just a 30 minute jaunt down the road. I'm originally from Baton Rouge, LA and I really LOVE central texas. I think I'll be here for awhile. The Mexican food is freakin' GREAT here. Not to mention the beautiful hispanic ladies. Man, I think I've died and gone to heaven sometimes. I didn't know what I was missing my whole life. lol!
If you upgrade to a cold air setup and are planning to supercharge later, I wouldn't spend a lot of money on one. Of all my mods, the CAI made the least amount of difference and with most SC setups you will have to ditch it later.
My first andbest mechanicalmods were long tube headers, steeda motor mounts (these are highly suggested to have done with the long tubes due to clearance issues) and the H-pipe/axle back. I didn't do the motor mountsalong with the headers and had to go back and have it done. When the long tubes are installed, they have to lift the block anyway so it's a perfect time to have them installed.
I also did a 1-piece lightweight aluminum driveshaft which is a great mod. I have a 4' one and am running into problems now that I'm mapping out my lowering plans. If I could go back, I'd have gone with a 3.5'. Plenty of those out there and you won't have the clearance issues later on.
I had plans to supercharge from the get-go and figured upgrading the exhaust and driveline would be most important due to that fact. Good luck with your Stang'!
Old Oct 28, 2007 | 03:17 PM
  #24
06Redfire3V's Avatar
06Redfire3V
ORIGINAL: craezjo
i would say x-pipe or h-pipe and longtubes, pioneer navi, and 4.10s if you have a good shop.
There is no way he could get all that and have someone install it for under $2500
Maybe everything cept for the longtubes
Old Oct 28, 2007 | 04:57 PM
  #25
drbobvs's Avatar
drbobvs
You should be able to get away with 4.10's in a manual, even with F/I. You'll need drag slicks, or at least drag radials at the track, but otherwise with a properly set up suspension, you should be able to hook OK. You'll probably want at least 275mm rear street tire if you don't already have them.My 255's BFG G-force's KDW2's will not hook on a WOT jump off the line, despite my suspension set up.
4.10's in a manual is virtually the same difference from stock as my 3.73's in my auto. But yes, many do stick with the stock gearing when going T/S due to the amount of off idle torque. If you know you'll be going F/I in the future, then yes, you may want to save even more moneyby sticking with stock 3.55's for the time being.
I'm still running the stock UCA, but yes I installed most everything else back there myself.
rgingo
Forum Issues and Feedback
Oct 21, 2015 12:49 PM
Dokilar
15
Oct 16, 2015 08:13 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
