CoilOver pros and cons
I'm looking to get the eibach coil over setup (gonna throw in a panhard bar as well) on my mustang http://www.tirerack.com/suspension/S...egory=CoilOver and the obvious pro that im going for is the handling of the car and I heard the ride is a little nicer, but what are the cons maybe worse weight transfer on launches?
I have aluminum coil over struts ordered that will have fox body spindles for several reasons. lightweight, can run lightweight fox body brakes, and better weight transfer for drag racing. this setup I am installing would probably only be worthwhile for drag racers that are trying to get every advantage they can out of there car. coil overs are nice, you just need to decide what reason you are installing them for so you can get the correct spring rate. I will be going with a softer spring rate about 175# where as if you are wanting it to handle better in the turns you would probably go with 200#or 225#. just need to talk with who you order from to set it up correctly
