Help: Replacing Brake Pads
Old Nov 2, 2007 | 10:59 PM
  #21
Argonaut's Avatar
Argonaut
Default RE: Help: Replacing Brake Pads
ORIGINAL: 05BlackPony
-Argonaut
I'm going to install Hawk HPS pads with RotorPros (Centric) Rotors Drilled/Slotted. Will let everyone know the results!
jmk3- Thanks for the heads up! I wouldn't want to pop the hood one day and see a chewed up strut tower!! []
Thanks again to everyone!
Thanks for the info. I'll get to the brakes one day, kind of thinking I'd upgrade the calipers to 4 piston w/14 inch rotors. Kind of expensive way to go...we'll see. Maybe a brake pad swap will be a good interim step.
Old Apr 5, 2008 | 05:03 PM
  #22
Stoenr's Avatar
Stoenr
No one ever mentions the direction you turn the piston to go in, I am assuming clockwise
Old Apr 6, 2008 | 05:56 PM
  #23
coopergs's Avatar
coopergs
I just put Hawk HPS pads on today. All I did on the rears is take a large c clamp to apply slight pressure to the piston and a set of channel locks ( tape the teeth to keep from etching the piston) and turn the piston clockwise. Mine compressed with no problem. I drive my car on the track so I also removed the dust shields to allow for better cooling while in the staging area before the next run. After bedding in the pads I feel I could stop the car from any speed on a dime and give change back! Good Luck.
Granatelli Sales
Jan 20, 2020 12:34 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
musnicki
Sep 23, 2015 07:11 AM
5.0 kevo
Sep 3, 2015 06:24 PM
dba Brakes
Aug 23, 2015 06:08 PM
