Dreaded Check Engine Light
Old Nov 4, 2007 | 12:42 PM
Mustangansta's Avatar
Mustangansta
Default RE: Dreaded Check Engine Light
they light came back - i cleard the DTC from the tuner and it went away but i feel it will return- what i need is a custom tune but if that was the case wouldnt it have come on months ago when i actually did the work?
didford charge you for testing it since you didnt have stock intake or other aftermarket parts and tunes?
Old Nov 19, 2007 | 01:14 PM
Mustangansta
guys whats up - my engine light came back on again and now its a P2196 code - i cant even find a listing for that one -whats up with the different codes thrown at me ?
any ideas ?
Old Nov 19, 2007 | 01:43 PM
grampa_stang's Avatar
grampa_stang
Here ya go:
P2196 O2 Sens Signal Stuck Rich bank1 Sens1
P2197 O2 Sens Signal Stuck Lean bank2 Sens1
P2198 O2 Sens Signal Stuck Rich bank2 Sens1
Old Nov 19, 2007 | 04:30 PM
Mustangansta
thanks a bunch... is this something i have to take to the dealer to fix ? will tthey charge?
Old Nov 19, 2007 | 05:31 PM
moosestang's Avatar
moosestang
Forgive my ignorance, but do you have a custom tune for the long tubes? If not then don't you need one or it will throw codes?
Old Nov 20, 2007 | 02:11 PM
Mustangansta
i have long tubes and a bama tune - but i have had it for almost a year with only one issue like this prior - and now all of a sudden its doing this - my question to the masses is how should i fix this - will it be an issue if i take it to ford?
djbigskrilla
Sep 20, 2022 01:04 AM
labudski
Aug 24, 2015 07:23 AM
microgt
Aug 20, 2015 07:12 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
