Racing Stripe Maintenance
Old Nov 8, 2007 | 05:19 PM
SeanoStang's Avatar
SeanoStang
Default RE: Racing Stripe Maintenance
ive heard good things from baltimore street mods in terms of vinyl
in terms of money for painted
mine was 1200 cuz i had mine custom mixed for me
Old Nov 8, 2007 | 05:55 PM
JWpony07's Avatar
JWpony07
I have very similar spots to you (not nearly as many.....yet) on my silver stripes (on a tungsten 07). I tried plexus, the mf towel i used to buff it off came out surprisingly dirty but the spots were basically still there, and this was immediately after a wash. I'll have to try the magic eraser, but other than that i don't know. I live in sunny so. florida so it could b sun damage, but it looks more like hard water and other deposits and discoloration that i apparently didn't clean off in time and now they're set in. I'm really tryin hard to find somethin that will work, i'll keep you posted if i find anything.
Old Nov 8, 2007 | 06:53 PM
optras's Avatar
optras
ORIGINAL: JWpony07
yeah, washing seems to make it look okay until it dries and then it goes straight back to the way it was. These started in small quantities too ("hmm...need to dry that better next time", etc.) but they've gotten bad in the last month. I'm not sure if there's going to be any kind of magical cure for them, I just wish I could garage it. [:@]
Old Nov 8, 2007 | 07:02 PM
marcuskeeler's Avatar
marcuskeeler
This depends on the vinyl and whether or not it's printed colour or actual factory colored vinyl. Factory colored vinyl shouldn't blotch,I feel in this case that it's probably cheap vinyl there.
When I print side stripes I laminate with clear vinyl over the top unless there's a specific reason not to, recently I did a set for Nate (on here) and couldn't laminate them as he wanted a very flat Satin finish. The trouble with non laminated printed stripes is that the life of the stripes is reduced as the ink is exposed to the weather and UV, plus,the more you try to erase blotches the worse they can get as you're basically chewing into the solvent ink.
optras's Avatar
optras
ok, after doing some reading around the tubes, people have reported the Eagle One wet spray polish works well. I'll also give Mr. Clean a try. Off to experiment, I'll keep you posted...should be back to let you know within an hour or so.
Old Nov 8, 2007 | 07:07 PM
marcuskeeler
I don't wail on my stripes, just wash them down and then give them some love with Simonez "ICE"
Old Nov 8, 2007 | 07:58 PM
optras's Avatar
optras
magic eraser didn't do a thing. sounds like my stripes are gonna come off soon cause my car's starting to get embarassing.
Old Nov 8, 2007 | 08:07 PM
speedstang06's Avatar
speedstang06
dumb quesion, but how do you clear coat the vinyl stripes?...
Old Nov 8, 2007 | 08:16 PM
optras's Avatar
optras
ORIGINAL: speedstang06
from what I understand they just spray it on over the factory stripes and it's supposed to make them sem-permanent and you wash and wax them like any other part of the car. This was a ford mechanic telling me this, I doubt he's make stuff up.
Old Nov 8, 2007 | 08:29 PM
speedstang06
aw, thanks for the info, I will probably go the vinyl route as well in thespring, with the clear coat can you still take the stripes off if needed?
