Tokico Dspecs/Bumpsteer necessary??
So basically I bought the car and it was already lowered (eibach sportlines).....but the stock shocks are still on there....I have two general questions...I just got my Tokico D-Specs in today and was planning on putting them on in the next couple of days.....i would be attempting it now but i just had Lasik surgery on my eyes today so i'll be out of commission for a day or two...anyhow it mentions using a bumpsteer change....is this absolutely necessary?......the other question is with sportlines ( i understand its lower than the prokit and a stiffer ride), but can i use the softer settings to make the ride a little smoother...or would it cause me to rub when i hit a bump/pothole?
The need for a bumpsteer kit is entirely dependent on the amount of lowering you've done.
My coilover setup lowered the Mustang three inches, so a bump steer kit was mandatory.
Below are two links to help you gain a general understanding of bump steer, and maybe help you decide if it's in your best interest.
Generally speaking, the tie-rod should be parallel to the lower control arm. If you peak underneath the vehicle, you'll be able to make a quick assessment. If it's not parallel, you'll have the drivability and possible tire wear problems mentioned in the links below. A bump steer kit allows you to make the adjustments needed to get it parallel.
http://www.mustangandfords.com/techa...ned/index.html
http://en.wikipedia.org/wiki/Bump_Steer
Ditch the springs for pro kit or similar drop. Sportlines are WAY too low. They actually HURT the performance of the car. Spend $200 on a set of springs and save yourself the headace. The Sportlines are gonna ride like **** anyway no matter what you do. It's just too damned low.
ORIGINAL: adidasUNT8
well crap....how difficult would it be to install the pro-kit then?
I am in the same boat, i got my D-Secs in today but i won't be installing untill i get the rest of my parts.
But I have the BMR spring kit, 1.25" drop in the front and 1.75" in the rear.
Do you guys think the Steeda bumpsteer kit will be required?
i think its looks good. it all depends how much you drive the car. i have the sportlines with d-specs and love it, but i will also sacrafice ride for looks and handling. if you have a daily driver, then the pro-kit is the way to go. i didnt even need an adj. panhard bar and its still good. jmo.........
Autobadges.com
Sep 2, 2009 09:52 PM
