Fat Tires
Old Nov 12, 2007 | 12:39 PM
LesteR723's Avatar
LesteR723
Default Fat Tires
I do autocross, and i often find myself losing front grip around hard corners. I have a set of sticky tires but it doesnt compare to the slick a lot of guys are bringing to the track. I was planning on getting a set of rim for Christmas with new tires... how wide can i go front and back? Thanks
Old Nov 12, 2007 | 02:09 PM
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Fat Tires
You can do up to 285 on the front, roush comes standard with 275 on all 4......the question is how big of wheels you got?
Old Nov 12, 2007 | 02:52 PM
06elnr's Avatar
06elnr
20x10s front and rear with 285-30-20s on all 4 corners.
Old Nov 12, 2007 | 09:43 PM
LesteR723's Avatar
LesteR723
im buying another set of rims to go with the tires. i dont want massive pretty sparkly chrome polished wheels, just ones that will get the job done on the track. 10" is as wide as it can go?
Old Nov 12, 2007 | 09:54 PM
06elnr's Avatar
06elnr
yes 10 is as wide as you can go...
Old Nov 13, 2007 | 01:28 PM
LesteR723's Avatar
LesteR723
alright htank y0ou
Old Nov 13, 2007 | 01:30 PM
06Redfire3V's Avatar
06Redfire3V
i plan on doing 305-35-18s out back
Old Nov 13, 2007 | 03:00 PM
Gene K's Avatar
Gene K
275/40R17 is a very common size and readily available unless you need 18's to clear a big brake kit. They work well with 9.5". Make sure you investigate therequired offsets.
BTW anything other than 17 x 8 or 18 x 8.5 and much off factory offset (+/- 5mm?) will boot you out of Stock.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
