Old Oct 22, 2015, 04:02 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Exterior Guides
Print Wikipost
How do i remove a deep scratch??
Old Nov 12, 2007 | 05:07 PM
Signify's Avatar
Signify
Default How do i remove a deep scratch??
some time last night or today i have this really deep scratch like if someone keyed my car. its above the rear right tire, and its about 10 inches long and was wondering how i can fix that?? it took of the main color too... is there a remedy for this? can i buy something at a local shop to remove it? autozone, pepboys etc..
id really appreciate the help!
Old Nov 12, 2007 | 05:31 PM
Thurman's Avatar
Thurman
Default RE: How do i remove a deep scratch??
You can try lite compound.
Old Nov 12, 2007 | 05:34 PM
05gtdriver's Avatar
05gtdriver
If it's through the clearcoat, you're gonna have to repaint it[&o], but there is a solution that won't break the bank. Many pro detail shops specialize in repairing scratches & chips. They fill in the scratch/chip with touch up paint(thinned down to match car's color) and use fine color sanding to blend it all together for a seamless repair. Not for the novice, for sure, but it would be much less expensive than having an entire panel repainted at a bodyshop. I beleive Eastwood Company has a kit to fix clearcoat scratches. Hope this helps.
Old Nov 12, 2007 | 06:19 PM
06GT4RAD's Avatar
06GT4RAD
Yep like 05gtdriver said you most likely will need to have this repaired by a body shop. Sounds to me if the color has also been damaged that you are down to the metal. You can do as he suggest to try and save a little money and try to look in the Yellow Pages for a company called Aero Colours I think it is. They are pretty good at hiding thing
Richard
Old Nov 12, 2007 | 06:21 PM
TPony's Avatar
TPony
If down to primer or metal, you may have to repaint...
Old Nov 12, 2007 | 06:28 PM
ArcticFrog's Avatar
ArcticFrog
I had a really deep scratch on my roof (from either a rock or a cat claw, not sure...my cats are on my car a lot in the garage but I don't know that a cat claw could go as deep as this scratch was) and when I took my car in to the body shop for other repair work I asked them to work on the scratch to get it as fixed as they could without repainting. They told me they'd do their best to get it to buff out.They did not tell me details of what they did but the scratch is totally gone now. So anyway, in the right hands deep scratches can disappear without repainting...just do some checking around.
Old Nov 12, 2007 | 06:33 PM
jbailer's Avatar
jbailer
The easy test is with your fingernail. If your fingernail catches in in, you're going to need to paint it. Most likely it will need painting. -Joe
Old Nov 12, 2007 | 06:41 PM
Mustang3GT07's Avatar
Mustang3GT07
Try and take it back to the dealer if it is under warrenty. i had a deep scratch on my hood i took it back to my dealer as soon as they opened up and they had there man that does all the touch up paint jobs do my scratch for free! I only had to leave it there for about a hour.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Sep 24, 2015 09:18 PM
