Dumb Tire Question...
Old Nov 12, 2007 | 09:05 PM
stanngg's Avatar
stanngg
Default Dumb Tire Question...
This may be a dumb question but...Does changing the stock tire size impact the speedometer in any way? Guy at my job said that this should be taken into consideration when changing tire size. I didn't know...thought I'd ask the experts....
Old Nov 12, 2007 | 09:18 PM
SnakeFan's Avatar
SnakeFan
Default RE: Dumb Tire Question...
Yes, unless you keep the total diameter the same. For example, you bump up to 18's, you need to bump the sidewall down to like a 40 or so. There are certain calculators around, even on this forum if I'm correct?
Old Nov 12, 2007 | 09:20 PM
howarmat's Avatar
howarmat
s197 Junkie
yes it does
Old Nov 12, 2007 | 09:23 PM
Stoenr's Avatar
Stoenr
http://www.miata.net/garage/tirecalc.html
Old Nov 12, 2007 | 09:26 PM
blike's Avatar
blike
Yeah, and when you're looking up tire specs it should have a revolutions/mile number to go with each tire size to compare to stock
Old Nov 12, 2007 | 09:31 PM
my first mustang's Avatar
my first mustang
Yes it does. All tires have a RPM(revs per mile) in there specs. section. Easy to change with a tuner,ie X/cal2,diablo predator to name two. Ford dealer can do it too.
Old Nov 12, 2007 | 09:57 PM
navyscott's Avatar
navyscott
Another good site...
http://www.bigcustomwheels.com/info_specs.jsp
Old Nov 12, 2007 | 10:05 PM
TPony's Avatar
TPony
Absolutely...get a hold of one of those tire calculators and it should tell you exactly how much off it is...
Old Nov 12, 2007 | 10:50 PM
davesyo's Avatar
davesyo
In general for approx every 1/2 inch difference in tire height your speedo is effected by 1 mph and the odometer by 1.6 % which may not seem like much but in 10000 miles the odometer will also be off about 160 miles. when going to a different profile tire you should stay within the recommended replacement height to maintain the proper tire load specs and service description
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
