Sponsored by:
Sponsored by:
crunching noise from suspension
Old 11-13-2007, 07:14 PM
oshkoshbajawsh
I ♥ Acer
oshkoshbajawsh's Avatar
Default crunching noise from suspension
lately when ive been entering my driveway or leaving my driveway (it has a sharp incline) i go up or down very slowly.. or when im leaving parking lots that have inclines, my front left suspension makes a crunching sound.. its totally quiet when im at cruising speeds i only hear it going slowly or whenever my suspension is really flexing.. any idea what this is before i take it to the dealership. i recently had the new strut mount part put in that fixed the front end thunking..
oshkoshbajawsh is offline
Old 11-13-2007, 09:02 PM
oshkoshbajawsh
I ♥ Acer
Default RE: crunching noise from suspension
bump[]
Old 11-13-2007, 09:05 PM
jmk3
jmk3's Avatar
Try greasing your LCA's. I had the same sound & that took care of it, make sure you use the synthetic grease that BMR recomends.
jmk3 is offline
Old 11-13-2007, 11:06 PM
oshkoshbajawsh
I ♥ Acer
and what if i ran out and only have tiny cartridges that dont fit a standard grease gun..
Old 11-14-2007, 04:41 AM
Simon1
Simon1's Avatar
I had something like that happen and it was my sway bar. It had loosened up over time and it needed a few twists on each connector. I put some lok tite on it lastime and it's been quiet since. You can do it with the tires on. 8mm wrench for the bolt and,,,I don't know the other size. Take a look and see. You need one wrench on the bolt and the other on the nut.
Simon1 is offline
Old 11-14-2007, 11:07 AM
oshkoshbajawsh
I ♥ Acer
front sway bar i presume you are refering to
Old 11-15-2007, 12:01 PM
sweetlou69
sweetlou69's Avatar
if its the sway bar it could just be the bushings.
sweetlou69 is offline
Old 11-15-2007, 03:17 PM
oi8achevy
oi8achevy's Avatar
swaybar link pins are notorious for that. see it alot in my shop. take them off and drive around. if the sound is gone get new link pins and bushings.
oi8achevy is offline
baddog671
07-26-2016 01:20 PM
Matt's 95 Stang
10-05-2015 07:16 AM
KingRando
10-02-2015 08:06 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: crunching noise from suspension
