Underdrive Pulleys
ORIGINAL: pascal
That was me Pin-head
Just kiddi'.
I do have a question though: Isn't the water pump run slower because of the UDP? And if so, is there a chance of overheating.
What's the limit on that one?
.Just kiddi'.
ORIGINAL: acascianelli
Most if not all UDP kits for S197 Mustangs come with an oversized water pump pulley that you also install.
ORIGINAL: pascal
Just kiddi'.
.Just kiddi'.
You're still slowing down the power steering, air con, and alternator. I'll give up a few horsepower to keep my cooling system working properly. You could always get an electric water pump and gain even more from a UDP.
I see you guys posting up your HP #s, I was under the impression that the stangs came out with 300 hp but you guys are listing all the mods and your barely over 300...Whats the factory numbers on the stang 4.6's
They have 300hp measured at the flywheel, the numbers people are listing are horsepower number measured at the rear wheels. Any car will lose horsepower through the transmission, differential, etc. Stock GT's measure between 255-270hp depending on the motor and transmission. Mustang's with automatic transmissions typically produce slightly less power than those with manuals.
My car dynoed at 324whp and 341 lb/ft tq...300 bhp/crank hp is the stock #'s
ORIGINAL: WPsharpshooter
